Dash clock info/help needed!
Old 10-05-2010, 08:44 PM
REDEM1FTW's Avatar
Icon3 Dash clock info/help needed!
I just installed a dash clock that I picked up in my eg hatch but after I get it installed and turn on the car the damn thing doesn't work! I've checked both under-hood and under-dash fuses and none are blown. I have one concern with the wiring for the clock; there are four pins on the plug that goes into the clock but only two wires that lead to the plug? (Yellow/red stripe and red/black stripe)
So my question is....Are there only supposed to be two wires for the clock plug? If so, what should he the next thing I check?
Thanks,
Josh
Old 10-05-2010, 08:54 PM
Wdpfreak145's Avatar
Default Re: Dash clock info/help needed!
Find your radio harness. On the factory plug there is a white wire with a blue stripe. That's the constant 12v. Trace It back to behind the cluster. It should splice in. If your model came with a clock from the factory, it would have another wire coming off of it which leads to the clock harness plug. If it didn't, it might not have the other wire coming ff of it.
Old 10-05-2010, 08:57 PM
REDEM1FTW's Avatar
My hatch is a cx so no factory clock. If I find that white/blue wire, where should I splice it to to run power to the clock?
Old 10-05-2010, 09:04 PM
Umm, one of the pins on the harness? I'm not sure which one. You'll also need to run the ignition 12v so it will actually turn on and that's gonna be a different color. The constant is so it can keep time. The ign 12v is for the clock to actually come on.
Old 10-05-2010, 09:08 PM
thakid's Avatar
Which model came with the clock?
Old 10-05-2010, 09:11 PM
Former User's Avatar
The clock should have 4 wires:
Yel wire - main power for clock from fuse 15
Red/Blk wire - power from fuse 19 for back lighting
Wht/Blu wire - power from fuse 32 for clock memory of time
Blk wire - ground
Old 10-05-2010, 09:13 PM
REDEM1FTW's Avatar
Mine came from an ex but I think lx /ex/si.
A diagram of the wiring would be awesome if anyone has one haha
Old 10-05-2010, 09:16 PM
REDEM1FTW's Avatar
Blk wire - ground
YOUR AMAZNG THIS IS EXACTLY WHAT I NEEDED AND THEN SOME haha thank you very much ron!
- Josh
LHDHonda's Avatar
maybe the clock you have is bad because i own a 95 CX without the Clock and i picked one off the junkyard from a sedan and it goes right in.... and worked.
car came with the clock plugs also..
Old 10-05-2010, 09:30 PM
He said he only has 2 wires coming into his clock harness plug.
Old 10-06-2010, 11:00 AM
Oh look, I can change this
deschlong's Avatar
B_Swapped93
11-10-2014 02:09 PM
FlewByU352
03-14-2010 05:58 PM
White cracker yeehaa
11-08-2005 05:27 PM
shivic
08-02-2005 06:03 PM
Quick Reply: Dash clock info/help needed!
