D16Y8 Oil Leak
D16Y8 Oil Leak
I been having this leak ever since I bought this car, so far Ive changed the distributor and Ive replace the Vtec Gaskets also the Valve Cover gasket and I still have this leak at this point I have no idea what it could be, any suggestions? Thank you in advance
Re: D16Y8 Oil Leak
Oil that drips to that area is usually either ditributor O-ring or cam seal.
A Vtec solenoid leak usually travels under distributor/ECU sensor and along the top of the transmission.
Did you use Hondabond or RTV sealant in corners (per FSM) during the valve cover gasket install?
Re: D16Y8 Oil Leak
No I didnt use Rtv or honda bond, and I changed the vtec gaskets along with the distributor and nothing has helped, Only thing I havent changed was the cam seal
Re: D16Y8 Oil Leak
Hondabond or Yamabond your Vtec solenoid seal. Clean both block and Vtec solenoid mating surfaces thoroughly and be careful not to get any on the screen. Also, Hondabond the valve cover gasket corners per FSM.
Vague
11
01-02-2016 08:21 AM
PatrickGSR94
12-19-2014 08:02 AM
