converting 4 wire O2 to 2 wire
1 Post
Just put in a Y8 harness to finish my Y8 conversion. I didn't plan on the harness have a 2 wire O2 sensor for the secondary O2. Wich wires are the ones that need hooked up. I guess I'll just take the 4 pin connectore off the old harness and leave 2 pins empty. This is on a 96 Y8 harness.
1 Post
Re: converting 4 wire O2 to 2 wire (brusk13)
ok maybe I've got something mixed up. What I thought was the secondary o2 sensor maybe it's not. It's a connector that looks just like the one going to the Idle Speed Control and is Y'd off the wiring harness under the intake manifold. I don't see any other connectors that could be for an oxygen sensor. The 96-98 does use a 4 wire secondary according to the manual.
1 Post
that's not good I don't see anything that could be the secondary o2. I see in the parts list that there should be an extension wire between the o2 and the wiring harness is that correct?
1 Post
ok looks like the connector I thought must be it is to the PS rack pressure sensor, which of course I don't have. So I still need to find the O2 wiring. I'll tear it apart tomorrow I guess.
EX-T
12
05-24-2008 08:01 PM
