code 36??? and 10
Old 01-28-2007, 02:56 PM
v8 integra's Avatar
Default code 36??? and 10
i have 2 problems.. 1.. i changed my IAT sensor and it still throws out cel code 10...2.. i get code 36 ...( 3 long flashess 6 quick flashes)but i cant find code 36 on this website.http://www.c-speedracing.com/faq/05.php
can someone pleaseee tell me wat else could b wrong with the iat sensor..brand new wire harness and brand new iat sensor.. 95 delsol b16 in my 96 civic ex.. thanks alot honda tech..
Old 01-28-2007, 04:16 PM
vsmhatched's Avatar
Default Re: code 36??? and 10 (v8 integra)
did you reset the ecu after you changed the sensor.....and there is not a code 36
Old 01-28-2007, 08:14 PM
v8 integra's Avatar
Default Re: code 36??? and 10 (GreyDel)
yes i did....idk..i got 3 long flashes and 6 quick1's..idk =[the iat is the sensor on the intake manifold right??
Old 01-28-2007, 10:12 PM
vsmhatched's Avatar
yeah 10 is the air intake temp sensor....
well hondaswap.com has a reference section for 88+ civic error codes, and i didnt see a code 36..it went from 31 to 41..pretty much skipped all the 30's....cause i dont believe there is any...check it out i guess
Old 01-28-2007, 10:13 PM
vsmhatched's Avatar
yeah its on the manifold...it should be a 2 wire plug that is white i think
Old 01-28-2007, 10:53 PM
fasthatchb18c1's Avatar
The only thing I can think of is when someone put on your wire harness it got pinched and messed up the IAT wiring.
To see if the IAT is working fine just blow a hair dryer at it and hoop up a ohm meter up to the sensor, If resistance drops as temp increases its fine.
If that's good its your wiring.
Old 01-29-2007, 07:07 AM
Braco11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8 integra &raquo;</TD></TR><TR><TD CLASS="quote">i have 2 problems.. 1.. i changed my IAT sensor and it still throws out cel code 10...2.. i get code 36 ...( 3 long flashess 6 quick flashes)but i cant find code 36 on this website.http://www.c-speedracing.com/faq/05.php
can someone pleaseee tell me wat else could b wrong with the iat sensor..brand new wire harness and brand new iat sensor.. 95 delsol b16 in my 96 civic ex.. thanks alot honda tech..</TD></TR></TABLE>
From the ECU thread at the top of the forum....
36: traction control found on JDM ecu's
Old 02-03-2007, 12:15 PM
v8 integra's Avatar
soo0o0 anyone know how i can fix my traction control cel.. code 36...and yes it is a jdm ecu..p30...and thanks for all the help guys!!
Old 02-03-2007, 06:54 PM
Braco11's Avatar
Default Re: (v8 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8 integra &raquo;</TD></TR><TR><TD CLASS="quote">soo0o0 anyone know how i can fix my traction control cel.. code 36...and yes it is a jdm ecu..p30...and thanks for all the help guys!! </TD></TR></TABLE>
i dont think you have traction control, so need to worry about it.
Old 02-06-2007, 02:01 PM
v8 integra's Avatar
but how do i get rid of the code??? i want v-teC!!!!!
Old 02-08-2007, 06:03 PM
v8 integra's Avatar
anyone!!??? =[
Old 02-08-2007, 08:23 PM
Braco11's Avatar
my code 36 never really pops up....sorry, can't help you there
Old 02-08-2007, 09:29 PM
Turbogixxer's Avatar
Default Re: (Braco11)
You have to get a non-traction control ECU to get rid of the CEL
Old 02-21-2007, 02:48 PM
gaborn73's Avatar
my buddy has the same error.
I just posted a new thread hoping to get
an answer. I will advise if anything comes up.
Old 02-26-2007, 02:32 PM
v8 integra's Avatar
thanks!
Old 02-27-2007, 12:45 PM
envee's Avatar
does iat code cause idle surge?
Old 02-27-2007, 08:10 PM
sauceja's Avatar
Default Re: (solbrothers)
Find wiring diagrahm of jdm P30 and find the wire for traction and just ground it would be my suggestion. Or get a chipped P28.
jonathan13
06-24-2009 08:39 AM
jonathan13
04-20-2009 06:21 AM
RSant
03-01-2007 10:28 AM
silentblackhat
05-01-2005 04:41 PM
Quick Reply: code 36??? and 10
