Clutch won't engage, help please.
Old 02-17-2010, 08:11 PM
Sn0man's Avatar
Default Clutch won't engage, help please.
I was on my home from work and the car started out all good and dandy, then after about 5-10 minutes I went to press in the clutch to down shift and the pedal went floppy and I couldn't get out of gear. I kept stomping on the pedal praying it would engage which it eventually did. Then I dealt with this the whole way home. When I arrived at home I managed to pop it into neutral and glide into my driveway. Unfortunately I couldn't get it to go back into a gear no matter how hard I tried, so I had to push it out and then up to the side of the road. Is it just a bad/loose cable??? Please help.
Old 02-17-2010, 08:23 PM
D16SiHatch's Avatar
Default Re: Clutch won't engage, help please.
well seeing as how you're in the 92-00 section i'm going to venture to take a guess that your car falls under that category. if that's the case, then your clutch is hydraulically actuated. check the reservoir to the right of the master cylinder and see if its low. check for leaks there and at the slave cylinder on the transmission.
Old 02-17-2010, 08:24 PM
sbpphoenix's Avatar
car specifics. nobody can help you if they don't know what car is it.
Old 02-17-2010, 08:25 PM
Sn0man's Avatar
Sorry thought my car was in my sig. 92 Civic SI hatch, stock D16Z6(just I/H/E).
Old 02-17-2010, 09:13 PM
Man U FTW
Schister66's Avatar
Most likely a hydraulic leak or you're running very low on fluid. I would start by checking that. Beyond those options, all that comes to mind is a bent shift fork (or whatever the little fork thing that actuates the throw-out bearing is called). Thats a bit more involved to fix...hope its the first option
Old 02-17-2010, 09:58 PM
DCSportEJ1Civic's Avatar
i think what your trying to say is that when you press the clutch pedal down the clutch doesnt disengage. as in you press the pedal while driving in a gear and nothing happens. can you shift the transmission when the car is off? when the pedal went floppy did if come back up on its own or stay down? Also have someone push the clutch in and release it while pull back the boot on the clutch fork and see if it moves like its suppose to or not. if it moves its not a leak issue, but something with the pressure plate or clutch itself, or a transmission issue.
Old 02-18-2010, 06:33 AM
Sn0man's Avatar
Yeah disengage, the pedal will stay down for the most part, on occasion it would pop back out.
Old 02-18-2010, 07:02 AM
318 Curves, 11 miles
Vindicator9000's Avatar
Yep. You don't have a cable clutch in your 92, you have a hydraulic clutch.
Your problem is most likely caused by lack of pressure somewhere in the system. I've had it happen to me before just by clutch fluid being very low. If the problem continues after you fill it, look for leaks. If no leaks, then you have a more involved problem.
Old 02-18-2010, 07:25 AM
Laz's EP's Avatar
First check to see if you have any fluid in the resovoir, if you do, try bleeding the system, if it doesn't work. It could be your clutch,CM cylinder, your slave cylinder or a leak.
Ask to previous owner(since you picked this car up recently) ask him if he has changed any of these. I was having the same issue after I changed my clutch and I replaced the CM and the slave cylinder and it was working fine until one day the pedal stayed al the way down. I noticed I had a leak on the hose right before the slave, so I believe thats my problem. Im changing the hose soon.
Old 02-20-2010, 08:32 PM
farrockb25's Avatar
im having tha same problem its just when im at idle i have to force it hard hard to make it go in but when im driving it it goes in good i notice when i was messing wit the tranny fork i seen it had shaved a lil and the bearing wasnt holdin on correctly could dat be my problem and when i shut it off it goes in good to someone help me
Old 02-20-2010, 11:13 PM
yellowjdmcrx's Avatar
i would say u have a leak like everyone else has said, eg's seem to be bad about the slave going out, have had a crap load of friends that the slave has went out. its a easy change. and to the cat above my post u sound like u have major probs if ur throw out bearing is not on there right and stuff. get that cheakc out
Old 02-21-2010, 01:05 AM
hatchet_honda's Avatar
huh??
Old 02-21-2010, 01:19 AM
check the lil fluid resvoir next to the master cylinder...you may have no fluid.
Old 02-21-2010, 10:20 AM
farrockb25's Avatar
i have fluid
Old 02-21-2010, 10:41 AM
jasoncanseeoh's Avatar
he has fluid, guys.
Old 02-21-2010, 10:52 AM
Originally Posted by jasoncanseeoh
he has fluid, guys.
hmmmm well then he has air in the clutch line to the slave cylinder or your slave is bad. investigate!
Old 02-21-2010, 12:36 PM
i would almost guess the slave is bad, did u have to put fluid in it anytime lately? otherwise there is really no way he got air in the fluid
Old 02-22-2010, 06:24 PM
check to see if the slave is moving the clutch fork when the clutch pedal is pushed down. if you can physically see the slave moving the clutch fork properly then there has to be an internal problem with the clutch. do this and narrow down what problem your looking for. it will tell you if the problem is inside the transmission or outside the transmission.
Old 02-23-2010, 09:43 AM
Sn0man's Avatar
Got it sorted out, just had to bleed it out. thanks guys.
Old 02-23-2010, 10:07 PM
omg all that and it was just air in the clutch line??
Old 02-24-2010, 04:32 AM
Type_R_Nammer's Avatar
when i narrowed it down, it came to the clutch fork...how on earth does it snap?!?!
Old 02-24-2010, 05:11 AM
Jimster480's Avatar
is the pedal hard? or does it stay at the floor? have you tried bleeding the system? its possible that you got air in it, especially if it works after you pump it a bit.
Old 02-24-2010, 07:58 AM
Sn0man's Avatar
I know right haha.
Read thread I got it fixed, it was a bleeding issue, thanks though!
Old 02-24-2010, 09:12 AM
doesnt look broke to me lol..was it the spring that broke?
Old 02-24-2010, 12:13 PM
Jimster480's Avatar
you dont see the huge crack in it?????
Quick Reply: Clutch won't engage, help please.
