cleaning head surface
Old 03-08-2009, 06:54 PM
thebleek's Avatar
Default cleaning head surface
what can you use with gasket remover to help get a stuck on intake mani gasket off? I dont want to scratch my head
Old 03-08-2009, 06:57 PM
Rheg6's Avatar
Default Re: cleaning head surface
some brake clean and a rag will work fine. or carb cleaner watever works. emory cloth should work good without hurting it too much
Old 03-09-2009, 10:18 PM
thebleek's Avatar
well its like glued on practically
Old 03-09-2009, 11:52 PM
trustdestruction's Avatar
scrape it off, no big deal.
Old 03-10-2009, 01:03 AM
94EGKUSH's Avatar
razor blade worked for me.
Try that then sand with 320 grit sand paper.
Old 03-10-2009, 01:15 AM
Davus's Avatar
I razor'd mine off after stuffing a few clean towels in the ports, didn't even get it all off and smooth, but the intake is now sealed. New gasket seems to have taken care of it.
You could carefully use a flathead screwdriver for bigger chunks.
Old 03-10-2009, 02:42 AM
thebleek's Avatar
I think when i installed the intake mani gasket, the old one that was stuck on may be causing my fluctuating idle problem
Old 03-10-2009, 05:12 AM
318 Curves, 11 miles
Vindicator9000's Avatar
scotch-brite pads and a die grinder works pretty good. They don't take off any metal if you're reasonably careful - the scotch-brite will disintegrate first.
Old 03-14-2009, 09:04 PM
FlatBlkEk's Avatar
gasket remover and time, then scrapping with a razor blade always works for me
Old 03-14-2009, 09:17 PM
biglou85's Avatar
use razor scratching method with razor 90 degrees to surface scratches gaskets off easy without making score marks
Old 03-14-2009, 09:33 PM
carfanat1c's Avatar
That makes no sense, try 30-45 degrees. 90 degrees would be putting it completely perpendicular to the head.
But yea like 94EGKUSH said razor blade and sandpaper, I went with a little finer than 320 though.
Randysi
11
10-24-2011 07:39 PM
akdrag
11
10-05-2009 07:14 PM
skaternak
09-27-2009 03:25 PM
builthatch
05-02-2007 06:50 PM
Quick Reply: cleaning head surface
