Chassis Code Cheat Sheet (Other Specs too!)
Old 06-03-2009, 01:40 PM
H-T White Ops
NOFX's Avatar
Default Chassis Code Cheat Sheet (Other Specs too!)
I will be using this thread to post chassis code information along with trim information in relation to different markets and any other specs I think might fit well within this thread.
PLEASE LINK TO THIS THREAD INSTEAD OF MAKING OTHER THREADS GO OFF TOPIC ABOUT CHASSIS CODES!
First, I'll post the "general terms" often used by people who are into Hondas.
What is an EG?
This can (in the scene) refer to either all '92-'95 (fifth gen / 5G) Civics or all '92-'95 Civic hatches. In reality it refers to certain fifth generation Civic hatches, sedans and del Sols.
What is an EK?
This can (in the scene) refer to either all '96-'00 (sixth gen / 6G) Civics or all '96-'00 Civic hatches. In reality it refers to certain sixth generation Civic hatches and sedans.
Then what is an EJ / EM / EN???
Oddly enough, "EJ" is a bit more confusing since it covers both fifth and sixth generations of Civics in the US alone. Nearly all US 6th gen Civics are EJs though, while all US 5th gen coupes are EJs. The only 6th gen Civics in the US that are not EJ chassis are the EM1 and EN1.
I believe I've gotten all the models covered in this section (besides five-doors and Aerodecks) in this short little list. I'm primarily into 6th gens though, so I'm sure I screwed up somewhere. Plus some of these codes are hard to come by.
Chassis codes rarely point toward just one particular engine. It's more of an engine "type". For example, an EK4 would come with some sort of 1.6L DOHC VTEC, which can include the B16A, B16A2, B16A4 and so on.
I'll edit this post if there is more information to post in it. If you have any missing information and have a good citable source, please PM me with the information and I will edit the post.
1992-2000 Civic and Del Sol Chassis Codes
Below I have included lists of what engine and body style each chassis code matches to.
The chassis code that your vehicle was first designated by the factory will never change, even if you do an engine swap or weld your rear doors shut. The only way an EJ6 will ever be an EK9 is if that EJ6 got melted down, sold to Honda, and Honda made that metal back into an EK9.
5G (1991-1995) Models:
EG3 - 1.3L SOHC non-VTEC 3 door
EG4 - 1.5L SOHC non-VTEC 3 door
EG5 - 1.6L SOHC VTEC 3 door
EG6 - 1.6L DOHC VTEC 3 door
EG7 - 1.3L SOHC non-VTEC 4 door
EG8 - 1.5L SOHC non-VTEC 4 door
EG9 - 1.6L DOHC VTEC 4 door
EH1 - 1.6L SOHC ?? 4 door 4WD
EH2 - 1.5L SOHC non-VTEC/VTEC-E 3 door
EH3 - 1.6L SOHC VTEC 3 door
EH4 - ???? SOHC ?? 4 door
EH5 - ???? SOHC ?? 4 door
EH8 - 1.2L SOHC ?? 4 door
EH9 - 1.6L SOHC VTEC 4 door
EJ1 - 1.6L SOHC VTEC 2 door
EJ2 - 1.5L SOHC non-VTEC 2 door
EJ3 - 1.6L SOHC ?? 4 door
EJ5 - ???? SOHC ?? 2 door
6G (1995-2000) Models:
EJ6 - 1.6L SOHC non-VTEC 2/3/4 door
EJ7 - 1.6L SOHC VTEC-E 2 door
EJ8 - 1.6L SOHC VTEC 2/4 door
EJ9 - 1.4L SOHC non-VTEC 3/4 door
EK1 - 1.6L SOHC VTEC-E 3/4 door
EK2 - 1.3L SOHC non-VTEC? 3/3 door
EK3 - 1.5L SOHC VTEC 3/4 door
EK4 - 1.6L DOHC VTEC 3/4 door
EK5 - 1.6L SOHC ?? 4 door 4WD
EK6 - ??L SOHC ?? 3 door
EK7 - ??L SOHC ?? 3 door
EK8 - 1.6L SOHC ?? 4 door 4WD
EK9 - 1.6L DOHC VTEC 3 door
EM1 - 1.6L DOHC VTEC 2 door
EN1 - 1.6L SOHC VTEC CNG 4 door
del Sol (1992-1998) Models:
EG1 - 1.5L SOHC non-VTEC
EG2 - 1.6L DOHC VTEC
EH6 - 1.6L SOHC (non-VTEC and VTEC)
EJ4 - 1.6L SOHC ??
So what are the chassis codes for US models?
Not all of the above cars are available in the US. You've probably heard a few (in particular EG6, EG9, EK4 and EK9) in reference to USDM cars, but those cars aren't were never available originally in the US.
Here are the chassis codes (and their matching trim levels, engines, etc.) that were originally available in the US. These account for about 99% of the Civics you see on the road in the United States of America.
The specs of these cars might vary slightly from cars sharing the same chassis codes in other countries.
1993-1995 (5G) Civic Coupes
*weights have not been varified by a reliable source yet.*
1993-1995 Civic DX coupe
Chassis Code: EJ2
Engine Code: D15B7
Engine Type: 1.5L 16-valve SOHC non-VTEC I4
Horsepower: 102 hp @ 5900 rpm
Torque: 98 lb-ft @ 5000 rpm
Compression Ratio: 9.2:1
Transmissions: 5MT/4AT
Weight: 2,224 lbs (92-93 M/T), 2,317 lbs (92-93 A/T), 2,231 lbs (94-95 M/T), 2,326 lbs (94-95 A/T)
1993-1995 Civic EX coupe
Chassis Code: EJ1
Engine Code: D16Z6
Engine Type: 1.6L 16-valve SOHC VTEC I4
Horsepower: 125 hp @ 6600 rpm
Torque: 106 lb-ft @ 5200 rpm
Weight: 2,290 lbs (92-93 M/T), 2,445 lbs (92-93 A/T), 2,552 lbs (94-95 M/T), 2,575 lbs (94-95 A/T)
1992-1995 (5G) Civic Hatches
1993-1995 Civic CX hatch
Chassis Code: EH2
Engine Code: D15B8
Engine Type: 1.5L 8-valve SOHC non-VTEC I4
Horsepower: 70 hp @ 4500 rpm
Torque: 83 lb-ft @ 3000 rpm
Transmissions: 5MT
Weight: 2,094 lbs (92-93), 2,108 lbs (94-95)
1993-1995 Civic DX hatch
Chassis Code: EH2
Engine Code: D15B7
Weight: 2,178 lbs (92-95 M/T), 2,275 lbs (92-93 A/T), 2,264 lbs (94-95 A/T)
1993-1995 Civic Si hatch
Chassis Code: EH3
Engine Code: D16Z6
Transmissions: 5MT
Weight: 2,326 lbs (92-93), 2,390 lbs (94-95)
1993-1995 Civic VX hatch
Chassis Code: EH2
Engine Code: D15Z1
Engine Type: 1.5L 16-valve SOHC VTEC-E I4
Horsepower: 92 hp @ 5500 rpm
Torque: 97 lb-ft @ 5000 rpm
Compression Ratio: 9.3:1
Transmissions: 5MT
Weight: 2,094 lbs
1992-1995 (5G) Civic Sedans
1992-1995 Civic DX sedan
Chassis Code: EG8
Engine Code: D15B7
Weight: 2,275 lbs (92-93 M/T), 2,343 lbs (92-93 A/T), 2,313 lbs (94-95 M/T), 2,392 lbs (94-95 A/T)
1992-1995 Civic EX sedan
Chassis Code: EH9
Engine Code: D16Z6
Engine Type: 1.6L 16-valve SOHC I4 VTEC I4
Weight: 2,480 lbs (92-93 M/T), 2,524 lbs (92-93 A/T), 2,522 lbs (94-95 M/T), 2,575 lbs (94-95 A/T)
1992-1995 Civic LX sedan
Chassis Code: EG8
Engine Code: D15B7
Weight: 2,319 lbs (92-93 M/T), 2,388 lbs (92-93 A/T), 2,403 lbs (94-95 M/T), 2,456 lbs (94-95 A/T)
1996-2000 (6G) Civic Coupes
1996-2000 Civic DX coupe
Chassis Code: EJ6
Engine Code: D16Y7
Engine Type: 1.6L 16-valve SOHC non-VTEC I4
Horsepower: 106 hp @ 6200 rpm
Torque: 103 lb-ft @ 4600 rpm
Compression Ratio: 9.4:1
Weight: 2324 lbs (97), 2342 lbs (98), 2359 lbs (99-00)
1996-2000 Civic EX coupe
Chassis Code: EJ8
Engine Code: D16Y8
Horsepower: 127 hp @ 6600 rpm
Torque: 107 lb-ft @ 5500 rpm
Compression Ratio: 9.6:1
Weight: 2507 lbs (97), 2504 lbs (98), 2513 lbs (99-00)
1996-2000 Civic HX coupe
Chassis Code: EJ7
Engine Code: D16Y5
Engine Type: 1.6L 16-valve SOHC VTEC-E I4
Horsepower: 115 hp @ 6200 rpm
Torque: 104 lb-ft @ 5400 rpm
Transmissions: 5MT/CVT
Weight: 2352 lbs (97), 2361 lbs (98), 2370 lbs (99-00)
1999-2000 Civic Si coupe
Chassis Code: EM1
Engine Code: B16A2
Engine Type: 1.6L 16-valve DOHC VTEC I4
Horsepower: 160 hp @ 7600 rpm
Torque: 111 lb-ft @ 7000 rpm
Compression Ratio: 10.2:1
Transmissions: 5MT
Weight: 2612 (99), 2601 (00)
1996-2000 (6G) Civic Hatches
1996-2000 Civic CX hatch
Chassis Code: EJ6
Engine Code: D16Y7
Weight: 2286 lbs (97), 2295 lbs (98), 2359 lbs (99-00)
1996-2000 Civic DX hatch
Chassis Code: EJ6
Engine Code: D16Y7
Weight: 2304 lbs (97), 2339 lbs (98), 2388 lbs (99-00)
1996-2000 (6G) Civic Sedans
1996-2000 Civic DX sedan
Chassis Code: EJ6
Engine Code: D16Y7
Weight: 2370 lbs (97), 2339 lbs (98-00)
1999-2000 Civic DX-V (aka SE or VP) sedan
Chassis Code: EJ6
Engine Code: D16Y7
Weight: 2361 lbs (99)
1996-2000 Civic EX sedan
Chassis Code: EJ8
Engine Code: D16Y8
Weight: 2568 lbs (97), 2511 lbs (98-99), 2513 lbs (00)
1998-2000 Civic GX sedan
Chassis Code: EN1
Engine Code: D16B5
Engine Type: 1.6L 16-valve SOHC VTEC CNG (Compressed Natural Gas) I4
Horsepower: ??? hp @ ???? rpm
Torque: ??? lb-ft @ ???? rpm
Compression Ratio: 12.5:1
Weight: ????
1996-2000 Civic LX sedan
Chassis Code: EJ6
Engine Code: D16Y7
Weight: 2489 lbs (97), 2412 lbs (98-99), 2410 lbs (00)
1993-1997 (3G) Civic del Sols
1993-1995 del Sol S
Chassis Code: EG1
Engine Code: D15B7
Weight: 2,295 lbs (93-95 M/T), 2,387 (93-95 A/T)
1996-1997 del Sol S
Chassis Code: EH6
Engine Code: D16Y7
Weight: 2,302 lbs (96-97 M/T), 2,388 lbs (96-97 A/T)
1993-1995 del Sol Si
Chassis Code: EH6
Engine Code: D16Z6
Weight: 2,414 lbs (93-95 A/T), 2,474 lbs (93-95 A/T)
1996-1997 del Sol Si
Chassis Code: EH6
Engine Code: D16Y8
Weight: 2,414 lbs (96-97 A/T), 2,474 lbs (96-97 A/T)
1994-1995 del Sol VTEC
Chassis Code: EG2
Engine Code: B16A3
Compression Ratio: 10.4:1
Transmissions: 5MT
Weight: 2,491 lbs (94), 2,522 lbs (95)
1996-1997 del Sol VTEC
Chassis Code: EG2
Engine Code: B16A2
Transmissions: 5MT
Weight: 2,522 lbs (96-97)
Other Helpful Links
6G Civic Trim Differences
The Ultimate Honda Chassis Code List
chassis code cheat sheet
Old 06-03-2009, 01:41 PM
H-T White Ops
NOFX's Avatar
Default Re: Chassis Code Cheat Sheet (Other Specs too!)
(Reserved for any other information.)
Old 11-30-2009, 04:53 PM
Seagull Management
94EG8's Avatar
At least some of the EG5s came with a DOHC ZC, specifically the 20th anniversary edition.
Excellent list though. Very helpfull
Old 11-30-2009, 05:01 PM
Scotty Dosent Know's Avatar
Great list thanks
Old 11-30-2009, 05:05 PM
backyard_concepts's Avatar
good stuff!
Old 11-30-2009, 05:19 PM
93egSLEEPER's Avatar
NOFX pulls through again. great write-up.... sticky material?? i vote yes
Old 11-30-2009, 05:21 PM
blackbndt's Avatar
X2 for sticky
Old 11-30-2009, 05:26 PM
It would end all disputes on here and keep new people from wasting thread posts and being confused... just like the motor swap info that is available.
Old 12-03-2009, 11:37 PM
fastrxu's Avatar
Theres countless threads where this list would have avoided pointless argumentative back and forth posts where neither party was right about chassis codes.
Lets just try to get it finished.
Good work
Old 02-16-2010, 09:19 AM
420eg95's Avatar
These are curb weight of factoy spec hondas
Sedan
'92-'93 DX M/T 2,275 lb (1,032 kg)
'94-'95 DX M/T 2,313 lb (1,049 kg)
'92-'93 DX A/T 2,343 lb (1,063 kg)
'94-'95 DX A/T 2,392 lb (1,085 kg)
'92-'93 LX M/T 2,319 lb (1,052 kg)
'94-'95 LX M/T 2,403 lb (1,090 kg)
'92-'93 LX A/T 2,388 lb (1,083 kg)
'94-'95 LX A/T 2,456 lb (1,114 kg)
'92-'93 EX M/T 2,480 lb (1,125 kg)
'94-'95 EX M/T 2,522 lb (1,144 kg)
'92-'93 EX A/T 2,524 lb (1,145 kg)
'94-'95 EX A/T 2,575 lb (1,168 kg)
Coupe
'92-'93 DX M/T 2,224 lb (1,009 kg)
'94-'95 DX M/T 2,231 lb (1,012 kg)
'92-'93 DX A/T 2,317 lb (1,051 kg)
'94-'95 DX A/T 2,326 lb (1,055 kg)
'92-'93 EX M/T 2,390 lb (1,084 kg)
'92-'93 EX A/T 2,445 lb (1,109 kg)
Hatchback
'92-'95 DX M/T 2,178 lb (988 kg)
'92-'93 DX A/T 2,275 lb (1,032 kg)
'94-'95 DX A/T 2,264 lb (1,027 kg)
'92-'93 CX M/T 2,094 lb (950 kg)
'94-'95 CX M/T 2,108 lb (956 kg)
'92-'95 VX M/T 2,094 lb (950 kg)
'92-'93 Si M/T 2,326 lb (1,055 kg)
'94-'95 Si M/T 2,390 lb (1,084 kg)
as you can see all hondas gained a few pounds every year, FYI: the oldr the lighter, at least when stock.
Old 04-10-2010, 09:43 PM
H-T White Ops
NOFX's Avatar
Glad to have been able to help.
I know I took down the full chassis code list in the other thread, but this information is as complete as I could manage to get it.
Might as well bump this again to let the newer members know.
Old 04-10-2010, 09:48 PM
David12's Avatar
great write up, another vote to sticky!
Old 04-11-2010, 07:57 AM
sholow213's Avatar
Old 04-11-2010, 02:12 PM
Jim Panse's Avatar
some additional infos for your list:
EH4 - 1.5L SOHC non-VTEC 4 door
EH5 - 1.6L SOHC VTEC 4 door
EH8 - 1.2L SOHC non-VTEC 4 door
EJ5 - 1.5L SOHC non-VTEC 4 door (1996- 2000!!)
EK5 - 1.6L SOHC non-VTEC 4 door
EK6 - 1.6L DOHC VTEC 3 door
EK8 - 1.6L SOHC non-VTEC 4 door
EJ4 - 1.6L SOHC VTEC
Old 04-11-2010, 02:21 PM
H23_del_soul's Avatar
Can we get some weights for the del sol's.....please? lol
Old 04-11-2010, 03:11 PM
acn911's Avatar
nice lots of help
Old 04-11-2010, 09:10 PM
H-T White Ops
NOFX's Avatar
Is there anyway you could give me your source? I just really don't want to spread false information or non-verified information.
I'll only add information I believe to be trustworthy to the first post.
Until I get some verification about the weights, I won't add them to the first post at all.
Old 04-13-2010, 02:31 AM
Jim Panse's Avatar
My source is the following:
http://www.hondaoldies.de/Korbmacher...onda/honda.htm
It lists almost all models, missing only a few.
The author is a Honda-addict who drove a lot of models himself.
Old 04-13-2010, 06:53 AM
Mr Fatty's Avatar
MB4 - 1996-2000 Acura EL (Canada)
Same specs as Civic EX 4 door with the D16Y8
Old 07-18-2010, 11:56 PM
aeaddy03's Avatar
great info!! i've been trying to figure this out for a while
Old 11-29-2011, 06:04 AM
H-T White Ops
NOFX's Avatar
Added weights to each listing thanks to 420eg95's post, info from the service manuals, and Team del Sol.
Old 11-29-2011, 08:31 AM
phabej_tony's Avatar
Nice write up, helps us noobs
Old 11-29-2011, 09:11 AM
Resident Gearhead
BryanM.'s Avatar
So the B16A3 has a compression ratio of 10.4:1?
Someone please correct me if I'm wrong, but I though all B16s were 10.2:1 in North America.
Trivial I know, I suppose that's just how I am.
Old 11-29-2011, 09:42 AM
Dat Dere Cell Tech
daklown's Avatar
goudam
Old 07-26-2012, 02:17 PM
dewey_civic's Avatar
So how come no one mentions the Special Edition Dx hatchback?
Quick Reply: Chassis Code Cheat Sheet (Other Specs too!)
