car wont start. starter wont even click. whats wrong?
so i went to start my 96 civic dx the other day and it wouldnt start. wont bump start, wont do anything.
i do hear the fuel pump prime, but when i turn the key over nothing happens except the radiator fan comes on. it stays on until i let off the key. nothing else happens at all. the starter doesnt even click.
i thought it might be the main relay because i thought i heard it making some noise, but i replaced it and had no luck.
i also noticed that the lights on the left side of the cluster, the oil and bat lights, are a bit dimmer than the ones on the right of the cluster.
i also checked all the underhood fuses.
could it be like a starter solenoid/relay or something?
its sitting in a snowy parking lot, so i would appreciate as much advise as possible before i try to go trouble shoot it again.
Re: car wont start. starter wont even click. whats wrong?
maybe alternator or ur battery is super *** died try givin it a jump first... but i had this prob after my swap the ground wire coming off the valve cover just needed to be removed and the surface it was touching sanded down started right up
check to see if you have 12v from your battery, then check all your grounds, maybe you just need a jump.
if it's stick then tell your friends to come help you push start it....or wwat you could do to see if it's the starter take a wire fromt he positive of the battery and put it black little sensor thing...it should crank or start if not then ur starter is the problem
could also be your battery
did you get this fixed?... if not give me a call... it seems like a ground got corroded and is not letting power get to your starter
still havent fixed it. im gonna try to check the clutch switch today, and see if i can hard wire the starter from the battery to see if it starts.....
JDM_d15b_eg8
10-11-2007 03:55 PM
BigRonDawg
04-19-2006 04:25 PM
Sexy_Chantal
10-28-2004 04:18 PM
