OEM sway bar bolt size on '95 EX.
Old 04-08-2014, 05:44 PM
JoeBlue's Avatar
Default OEM sway bar bolt size on '95 EX.
My car still has the original OEM sway bars installed, well sort of. I seem to have misplaced the outer link nuts that attach the swaybar to the LCA on the front swaybar, as well as the bolts that run through the bracket and into the subframe.
Would any of you happen to know these part numbers or the actual threading for these off hand?
If you must know I had the whole front end disassembled, so losing those in this mess is not bad. Unfortunately, I had someone else helping me, so I'm sure he is the one that misplaced them.
Old 04-08-2014, 06:04 PM
B_Swapped93's Avatar
Default Re: OEM sway bar bolt size on '95 EX.
M10x42mm and M8x20mm
you could just look at a diagram on majestic or something lol
Old 04-08-2014, 06:23 PM
GDD Member
slomofo's Avatar
8x1.25
Old 04-09-2014, 02:49 PM
JoeBlue's Avatar
^^ Isn't everything under the car M*x1.25? I have to order a helicoil kits, and everything seems to be 1.25 under there.
Dude, I was covered in power steering fluid when I posted that. I was trying to avoid getting it all over my computer. I have a waterproof keyboard for the garage, but not sure how it will hold up to fluids. Also Majestic has proven to be not 100% reliable for me. I have a coupe bumper and some other parts in the garage that display this...
Thanks for the sizes, I ordered them along with the exhaust studs and whatnot.
Old 04-09-2014, 06:49 PM
the x20mm x42mm were the lengths slomofo....
nghtshd88
03-04-2012 02:32 PM
bleedblue94
Suspension & Brakes
14
03-29-2009 07:57 PM
lib
03-25-2007 01:41 PM
rybred
Honda S2000
02-14-2007 03:18 PM
24hourflipness
14
05-02-2003 09:53 AM
Quick Reply: OEM sway bar bolt size on '95 EX.
