car shakes when accelerating
Old 06-17-2011, 05:05 PM
tundra2000's Avatar
Default car shakes when accelerating
I got a 1994 honda civic hatch with b20 turbo. I know this has been posted alot but what i get from it is ur motor mounts bad, and is ur cv axle bad, but how do i check to see if the motor mounts are bad, and when i turn the wheel to the right i can hear a clicking coming from the front driver side and when i checked it the outer and inner boots were broken, but would a that bad of cv axle cause it to shake when accelerating from 1st through 3rd?
Old 06-17-2011, 05:28 PM
apexi_rsx's Avatar
Default Re: car shakes when accelerating
if its vibrating bad when accelerating something is out of balance and can cause major damage. is the clutch ok nothing broken? yes i would assume the cv joint is bad but this should not cause vibrations when accelerating
Old 06-17-2011, 06:19 PM
tundra2000's Avatar
yeah the clutch should be ok, the guy i bought the car from put in a stage one or stage two clutch but it does feel fine
Old 06-17-2011, 06:24 PM
apexi_rsx's Avatar
what kind of flywheel OEM or aftermarket? is so what kind? is it lightened?
Old 06-17-2011, 10:31 PM
appelsos's Avatar
your axles could be the entire root of the problem. depending on how bad they are they can absolutely cause all that vibrating when accelerating.
Old 06-17-2011, 11:00 PM
MrNastyEj2's Avatar
More than likely the cv joint is bad. Could be a rough wheel beaing or a damaged axle as well.
Old 06-17-2011, 11:14 PM
Master Detailer
98civdx's Avatar
What axles and what mounts do you have?
My friend's old car shook very badly. New mounts(innovative) and axles almost got rid of all vibrating. Of course the mounts can cause a little vibration because they are stiffer.
Old 06-18-2011, 04:10 AM
Resident Gearhead
BryanM.'s Avatar
It's actually very common for bad CV joints to cause vibration under acceleration.
Old 06-18-2011, 12:38 PM
tundra2000's Avatar
http://www.youtube.com/watch?v=sUqiReGdb4k
I went out their and used my phone to record it, so how much would it end up costing to replace them?
Old 06-18-2011, 01:23 PM
hondatuner34602's Avatar
u def knw when u got bad motors mounts if the motor moving alot when u accelerate or deaccelerate it will feel like the whole car is shaking. according to the vid u posted they dont look that bad have a friend power brake and check for stress cracks on the rubber part of the mount replace it with some strong one like poly ones or oe if u cant afford them. but it does sound u got a bad axel or possible bad tires to
Old 06-18-2011, 02:17 PM
tundra2000's Avatar
yeah i was power braking it, but with the car off i can see small cracks
Old 06-18-2011, 02:27 PM
95EG2's Avatar
sounds like a bad axle esspecially if it clicking... check for worn motor mounts
Old 06-18-2011, 09:56 PM
jdsihas's Avatar
looks like you need motor mounts
Old 06-19-2011, 06:29 PM
Master Detailer
98civdx's Avatar
Are you running torque mounts?
I would replace the mounts. That things all over the place!
Also adjust those dang valves lol
Old 06-20-2011, 12:25 PM
tundra2000's Avatar
Do the valves need adjusting? and for mounts should i go with polyurethane motor mounts. but for now till i get the money to replace them is their anything i can do or use for a temporarily motor mount fix?
Old 06-20-2011, 12:31 PM
JDMek9santos's Avatar
+1 post count
Old 06-20-2011, 01:45 PM
tundra2000's Avatar
and shouldn't the rubber part in the mount suppose to fill the whole mount, cus when i look at it i see the top part but theirs no rubber on the bottom part, is that normal?
Old 06-20-2011, 02:12 PM
geek504's Avatar
Originally Posted by tundra2000
...the valves need adjusting?...should i go with polyurethane motor mounts...
I've seen pro dragster do a valve adjustment on each pass.
As for street driving, it wouldn't require that unless you race it.
And regarding your options for motor mount:
temporary fix would be buying the polyurethane...
if you have money you can buy the billet racing mounts.
but if you don't like the stiffness and vibration, get the oem mounts. But that will crack eventually through time if you abuse your motor.
Old 06-20-2011, 03:15 PM
Master Detailer
98civdx's Avatar
Yes, I would adjust the valves you can clearly hear them in the video.
You can try filling the mounts for now, it would hold the engine alot tigher, but this will cause the car to viberate. Not like it is now, but it will. The tighter the engine is held in the move viberation, however, the engine will NOT move like that ever again.
Your jokeing right?
It doesn't matter if the car see's 10k every day or never goes above 3k. They will all sooner or later NEED a valve adjustment. You can very clearly hear the valves clicking in the video, this would tell you the vales need to be adjusted.
Old 06-20-2011, 07:43 PM
geek504's Avatar
Originally Posted by 98civdx
.. They will all sooner or later NEED a valve adjustment. You can very clearly hear the valves clicking in the video...
Okay, I'll refrain. Some people would adjust it every 2nd oil change; others would adjust it during a timing belt/water pump job. And finally, some dealership would do it on the 30k mark.
...what I meant of my statement was, similar to the 3k miles oil change theory. You don't have to change your oil every 3k miles. It all depends on the situation. Sometimes you have to change it earlier, and sometimes you can change it a little later. "It all depends on the use of it".
...as for the video, to me, I don't think you need an adjustment yet because it is not that rough. But as I mention.... you can do the adjustment if you like. That's my thoughts.
Old 05-12-2013, 07:57 PM
05foresterxt's Avatar
I recently replaced the front passenger axle on a 99 si and now there is a shaking while accelerating. Its that bad but i can definately feel it. The axle is from Oreilly since i could not take apart the oem one to fix a ripped boot. The shaking was not there before replacing the axle.
Ive replaced every motor mount on the car except for the rear one. Ive looked at it and it has some cracks on the rubber.
Old 05-12-2013, 08:02 PM
Earthworm Jim's Avatar
Check the axles and the motor mounts. My money is on the mounts. It's possible that you have frame damage and just don't know it. You should post pictures of your engine bay and give the guys here a second look at it if you're still having the problem.
kwkid133
01-12-2012 06:00 PM
overtwo
02-21-2008 10:05 AM
STUCKED
02-08-2006 10:45 PM
Hondasaurs
05-22-2003 03:56 PM
MisterB
05-09-2002 03:54 AM
Quick Reply: car shakes when accelerating
