car runs hot after 10 minutes
#101
Re: car runs hot after 10 minutes
hi, yes cooling fan fuse good fan relay is good, and the fuse under the dash, and under the hood are good, and if i jump the wires to the switch with a paper clip, the fan will come on. i just want it to turn on the way it is suppose to, like factory. thanks arthur
#103
^Have you replaced the relay yet?
Glad to hear your coolant is finally running like it should. It sounds like your pump was just bad. If it sits around half on the temp. gauge while you move without a fan, it should be fine now, the air through the gauge takes up the work of the fan but obviously won't when the cars at a stand still. D series parts don't usually go over to B's no problem. A new tps will probably solve your problem but you should wait for a second opinion on here, I'm not a B series guru.
At least the car is drivable now. These other problems are minor but annoying.
#104
Ive had this problem and I swear it was an air pocket the whole time.
#105
If it sits around half on the temp. gauge while you move without a fan, it should be fine now, the air through the ***RADIATOR*** takes up the work of the fan but obviously won't when the cars at a stand still.
***I agree with the statement above. Hes right.***
***If your talking about the TPS sensor yes they do swap over just fine. You just swap the whole throttle body or, if you have the know how, you can successfully swap the TPS. The Y7 motor is an exception cause the throttle body faces up but again the sensor itself will work. Most sensors are interchangable exept for the IACV on some models the IATS but can be plugged in into another location. As far as everything else, hardparts, intake, exhaust, motor internals, no. ***
#106
hi how about the engine coolant tempature sensor under the distributor? should i change that to see maybe if the fan turns on when it should, and maybe it will cure the high idle also. let me know what you think. thanks everybody
#107
so everything is more or less normal now? my b16 swapped coupe sits about 1/3 of the way up on the temp gauge and was the same with the d15. sitting right at half isnt bad, but if you can throw a lower temp thermostat in there i would, just for piece of mind.
#109
hi soi how about the engine coolant temp sensor under the distributor, what is the purpose of that? should i change that to se if the fan turns on when it is supposed to, maybe it will cure the high idle to? let me know friends
#114
Yes. You need to do a quick mod though.
Keep the B series mounting bracket on the engine, then mount the D series alternator bracket to that mount and it lines right up to the belt drive.
EDIT: You need to use a fairly long 14 mm bolt and nut to push the alternator out to line it up. Should've said that in the first place. Here's a link for you.
http://www.homemadeturbo.com/f8/how-...-series-56044/
#115
thanks special brownie. just what i wanted to know. i have i high output d series alt that i wanted to put on my b16. your the man. thanks again.
#116
So you figure out what the problem was with your cooling/thermostat situation? Is your temp. gauge to normal(1/3-half down)?
#117
im not sure how i fixed the problem but the guage is around half, but the fan still will not kick on. i replaced the temp switch, and the switch under the distributor, and still no fan. but it will turn on when i jump the plug with a paper clip. i have it hooked up to a toggle switch for now. i took the car off the road for the winter.i also noticed i have a little oil under the distributor it sits on where the block and head attach. like under the distributor, the top part of the block, and bottom of the head, i cant figure where its coming from, and why. i clean it, take the car for a ride, and come back and check, and there is some oil there again.
#120
thanks guys, you are all very helpful. god bless all of you, for all the help you have given me through this first engine swap. thanks again. arthur
jdmspoonitr
10-13-2006 05:10 PM
EGhatched
14
03-27-2004 05:15 AM
