Cabin light
Old 02-02-2016, 03:13 PM
White_EG1's Avatar
Default Cabin light
So after a friend got the belt stuck in the door jam and closed it, my cabin light doesn't come on when you open the door. It's very annoying, I tried multiple things.
It's the rubber stopper thing on the bottom left of the door panel I believe. When I press it, the light comes on and off... So does anybody know how I can fix this?
Old 02-02-2016, 06:47 PM
jonsey1886's Avatar
Default Re: Cabin light
Remove the rubber cover
CAREFULLY extract the 2 bolts or screws that hold the metal door jamb plug in
CAREFULLY remove the door jamb plug using a pair of needle nose pliers. Be mindful of the two wires running to it which are usually easily damaged.
Using the needlenose and a straightedge straighten it back out so it is true again
Re installation is the reverse of removal.
If this doesn't fix it go to the local Pick n Pull and get a replacement from a donor car.
Old 02-03-2016, 09:34 AM
White_EG1's Avatar
Wow, thanks a lot man....
Might as well close this thread lol
Old 02-03-2016, 12:22 PM
Former User's Avatar
OP - Car information is required for all tech threads.
Also let us know if the suggestion fixes the problem.
Old 02-03-2016, 03:52 PM
White_EG1's Avatar
Oh my bad, 93 del sol with the d15b7.
Old 02-03-2016, 06:18 PM
jonsey1886's Avatar
Notice the word CAREFULLY. It is incredibly easy to break the metal jamb piece as well as the 2 wires that run to it. Been there done that.
sixpack595
Honda Civic (2001 - 2005)
12-23-2011 05:45 PM
Dc2 Joe
09-18-2009 08:51 AM
bopbop93030
05-14-2008 12:45 PM
19jetta91
04-21-2007 10:50 AM
tchen415
12-01-2006 09:44 PM
Quick Reply: Cabin light
