Brake lights dont work!
Hello HT well I have a 1994 ej1, and the other night i relize that my brake lights are not working, so i checked the bulbs and fuse and they are fine, so I took a test light and disconnected the harness that connects to the brake switch and no terminal is getting power, what could it be?, or can someone plz give me a wiring diagram for this thank you
Re: Brake lights dont work!
I dont have a horn. But what i did do is try to jump the connector and nothing either ik the ground is good because I tested it something in the postive wireI tried looking for one but I cant find one
Why don't you have a horn? What was done to remove it?
The wire that runs from the hood fuse box to the brake light switch on the pedal seems to be broken. Locate the break or run a new wire.
I bought the car without it already, I would like to put one in to have one, ok i would like to locate it instead then run a new wire, hows the best way for me to trace this wire?
alright I replaced my brake light switch, and it still doesnt work, so i guess its one of the wires from the connector that isnt good
Chris_A
07-28-2017 08:54 AM
dbailey
07-25-2010 10:24 AM
