Wiring Harness Keeps Burning Up. WTMF !
Old 08-25-2010, 06:48 AM
RMX_EF9's Avatar
Default Wiring Harness Keeps Burning Up. WTMF !
Ok, Few Days Ago ... My Civic (2000 4Dr D16y7) Burned Out Fuse #15 (7.5Amp Fuse) ... Since Then Ive Replaced That Fuse, But Now My Harness Keeps BURNING Up In Spots Starting At The Firewall On The Drivers Side. WTF. Ive NEVER Had This Problem Before ... NEVER. Just Seems Weird I Have No Mods Whatsoever, Suddenly Blow A Fuse #15, Then My Harness Starts Burning Up.
Help ! lol Im Trying To Keep My Car From Burning To The Ground :X
Old 08-25-2010, 07:17 AM
EJ-1's Avatar
Default Re: Wiring Harness Keeps Burning Up. WTMF !
one of the wire is getting heated up which caause all the other wires loom to it to burn also..recheck all the wires an ground..mainly check the lines that have power..u need a vault meter to check...previous owner prob tried wiring some ****..
Old 08-26-2010, 06:48 AM
RMX_EF9's Avatar
Ok, Check This, Pulled The Harness Back, And ReWrapped Them Up ... Car Atleast Runs Halfway Normal Now, But Im Pulling A CEL Code 0 ... And Tranny (auto) Shifts Are RIDICULOUS. Fluid Level Is Normal On The Tranny. Crap Keeps Getting Weirder And Weirder ... Idle Is Off From What It Was Also.
Fried ECU ?
Old 08-26-2010, 08:27 AM
ludesrv's Avatar
Sounds like you have an exposed 12V source. Enough to draw upwards of 7.5 Amps (that's alot, 1 Amp can stop a human heart). Remove your harness and examine it. There should be a broken or worn wire. To be safe, remove the fuse and leave it off for now so your car doesn't burn to the ground while your sleeping, or working, or at the gym, or whatever.
I had a similar situation; I replaced the full harness. Was easier then you think! Cost 40$ for a new harness from a wrecking yard too, but I had to pull it myself.
Old 08-26-2010, 08:54 AM
Momentum's Avatar
The wiring harness rubs against the intake manifold bracket Underneath the manifold alon the firewall wearing through the insulation and causing a short, I just had this happen to me last week. There was a recall for this for 96-99 civics. Take a look at the harness very closely underneath the IM bracket, tape up any exposed wires.
Old 08-26-2010, 09:03 AM
Former User's Avatar
Click Fuse 15 TSB in my signature.
Old 08-26-2010, 09:29 AM
RMX_EF9's Avatar
Checked, Thats The Fuse That Started This !
Yea, Harness Is Burned Pretty Rough Though ... Ima Swap That Out, And Go From There ...
96GeeSR
Audio / Security / Video
03-03-2009 12:02 PM
503_EF9
05-18-2007 08:50 AM
usdm.ehtu
03-17-2007 07:54 PM
pr0jektezek1el9
10-20-2004 10:16 AM
highmilehatch
07-23-2003 07:48 AM
Quick Reply: Wiring Harness Keeps Burning Up. WTMF !
