Bolt broke off in subframe brkt, help!
Old 09-14-2014, 06:19 PM
sk8shorty012's Avatar
Default Bolt broke off in subframe brkt, help!
The car is a 2000 Civic Si.
I was installing the RR sway bar bracket when the bolt snapped off in the subframe / weld nut.
There's nothing sticking out on either side and I tried a "screw extractor" but it snapped off when I applied torque to loosen the stuck bolt.
Any suggestions?
Old 09-14-2014, 06:56 PM
Oaken81's Avatar
Default Re: Bolt broke off in subframe brkt, help!
I would have tried drilling it out before using an extractor.
You could try using a MAP gas torch and heating the broken bolt up and try to extract it again.
Old 09-14-2014, 08:14 PM
MisereNoire's Avatar
Penetrant, let it soak overnight, center punch (hammer and punch) the sheared boltto guide the drill bit, drill out hole large enough for a decently large extractor to wind it out.
Old 09-14-2014, 09:33 PM
jdmcivicsi187's Avatar
Yup do as they say it should come and if that dont work put some heat to it
Old 09-14-2014, 11:28 PM
slightly_hackish's Avatar
Harbor Freight sells left-handed drill bits. If it doesn't come out while drilling, then you've got a larger hole for a bolt extractor.
Old 09-16-2014, 06:34 AM
ejv8s10's Avatar
I had the same thing happen.
I tried all the normal extractor tricks and kept failing miserably.
I got out the MIG welder and welded a 3" bolt to the broken stub.
That gave me a new bolt head to put a socket on. I think the heat from the welder also helped loosen the broken bolt.
I like my R
08-24-2023 08:56 PM
commotion
03-03-2009 07:24 PM
HCivicSi23
07-14-2007 11:15 PM
hellas
01-21-2003 12:33 PM
Quick Reply: Bolt broke off in subframe brkt, help!
