Battery Stabilizer or Voltage stabilizer?
Old 12-30-2011, 03:23 AM
9tailsfox's Avatar
Icon2 Battery Stabilizer or Voltage stabilizer?
Hello everyone here, I'm a little bit confuse both of these devices work. They both mount at the battery terminal. But any big difference between both device or just the name is difference? Thank you
Old 12-30-2011, 04:34 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Battery Stabilizer or Voltage stabilizer?
Leave these alone. I've heard nightmare stories about these.
Old 12-30-2011, 04:52 PM
9tailsfox's Avatar
Icon2 Re: Battery Stabilizer or Voltage stabilizer?
happy new year bro. I don't know much about electronic thing. just heard some good feedback about installing above device will good to alternator, better stabilize voltage and high rev. So it may depend what brand you are using.. if is cheap brand may cause problems. anyone using these devices? thank you
Old 12-30-2011, 04:59 PM
The Grumpiest
Where are you people "hearing" this stuff from? If your charging system is in order these are totally unnecessary. Don't believe the advertising hype.
Old 12-30-2011, 06:14 PM
Hidenplanvew's Avatar
These things work when there is less then accepted grounding (Subaru's benfit from these), but Honda has done a pretty good job of putting grounds on their motors... You could enlarge(use larger gaug wire)/clean the grounding points and see very little effect. Odds are if you cleaning your grounds would work just fine.
Since the spark plugs groung via the head It could produce a stronger/cleaner spark or sensors that ground via the engine would work more efficently but over all you dont need them.
Old 12-31-2011, 04:35 PM
9tailsfox's Avatar
some information that I found
http://www.importtuner.com/tech/impp...n/viewall.html
Old 12-31-2011, 04:43 PM
The Grumpiest
You believe everything you read in magazines? Go ahead and pick one up and install it.
Old 12-31-2011, 04:54 PM
9tailsfox's Avatar
I think those VS device is to reduce the lost of voltage and power lost to the minimal instead of gaining. I guess is up to user who willing to pay for the device cost. My friend who is wise enough to make a D.I.Y Voltage Stabilizer. He said that it was a simple device to make and it work, price cheaper than those brand name VS device.
Old 12-31-2011, 04:58 PM
The Grumpiest
Then get your friend to make one and install it. Don't know why you haven't already if you trust your friends work. Overall it will not make any noticeable difference.
Old 12-31-2011, 05:10 PM
Nobody123's Avatar
Please contact the specific manufacturer and ask them what exactly their system is designed to do. These are marketing terms and I have no idea what they mean either.
Also keep in mind that there are systems like the Battery Tender which is designed to keep a battery in storage from dropping voltage. It could be considered a form of battery or voltage "stabiliser".
Old 12-31-2011, 05:13 PM
9tailsfox's Avatar
My bad. The voltage stabilizer D.I.Y from my friend is very simple. Just direct putting all those capacitor on a PCD board like this picture. But the matter is we don't have dyno system to test it. So we never know what is the gain from it. But we sure that the thing he made is run properly. We just thought that maybe those after market brand make it more unique. But for me, it just a very simple device. Even I'm a electronic dummy can make one. oh yeah the casing from Brand name is way nicer than my friend's DIY( more ugly looks)
Old 12-31-2011, 05:19 PM
Ya theres not much of a diffrence... putting it on a dyno would be a waste of money... it just makes the system run more smoothly... Your honda wont see anything...
Old 12-31-2011, 05:28 PM
9tailsfox's Avatar
I see... but sometimes it just can't resisted for those who addicted upgrade. I'm mean is not a big money upgrade but something is affordable and you expect the thing work as describe. even it says possible increase 10 torque or 1 hp for the device cost only 30 dollars.
Old 12-31-2011, 07:02 PM
Former User's Avatar
Don't fool with Mother Nature (=Honda).
Old 01-01-2012, 08:49 AM
9tailsfox's Avatar
Yes Sir... ^.^
Old 01-01-2012, 02:05 PM
You wont gain anything... You could make it for cheaper if you really want to do it.. I doesent need to be larger then 12gauge wire
fleabag
07-02-2012 09:39 AM
lowlife9
Honda Civic (2001 - 2005)
05-08-2009 09:12 AM
I Like Hondas
20
10-18-2006 01:54 PM
88crx-si
11-02-2005 07:45 AM
Riceburner247
10-12-2005 07:04 PM
Quick Reply: Battery Stabilizer or Voltage stabilizer?
