B18b 02 sensor wiring question
So, I'm a cheep bastard and I don't want to buy a new 02 sensor, the plug fore the harness is 1 wire and there are 4 wires on the sensor, is there anyway i could wire them together in order for my 02 sensor to function properly and I can pass inspection, or am I asking the impossible.
Re: B18b 02 sensor wiring question
Is the ECU for your Civic OBD-0, OBD-I or OBD-II? If your (1-wire O2 sensor) harness is matched to your ECU, then maybe you can do what this guy did:
http://groups.google.com/group/alt.a...f3fec47a163f6#
Seagull Management
You're totally right about being able to use a 4 wire heated O2 sensor with an ECU that looks for a single wire O2 sensor though, a lot of guys running D15B Vtec swaps with the proper P08 ECU do that.
PR4 OBD1 ecu, it's a 95 jdm b18b, It's the only thing holding me back from passing inspection, I might try that idea 94eg8
Technical Hero
I think the problem with that idea above, unless I'm missing something, is that the ECU will still be looking for the heater circuit thereby throwing a CEL. If your state doesn't care about check engine lights for OBD1 you'll be in the clear. This trick will make the O2 function and will pass visual but you'll still have a CEL unless you can trick the ECU somehow.
phbrush
27
12-17-2014 07:25 AM
tomek5x
01-21-2008 09:56 AM
