Are 90-93 Coilovers Interchangeable with 92-95 Civics???
Old 07-26-2003, 03:05 PM
importimage's Avatar
Default Are 90-93 Coilovers Interchangeable with 92-95 Civics???
One of my friends has 92 Ground Control Integra coilovers that he wants to sell and I have a 92 civic hatch and want them. He is upgrading to expensive tein stuff (He has major $$$$)
Will they swap into my car?
Old 07-26-2003, 03:26 PM
Default Re: Are 90-93 Coilovers Interchangeable with 92-95 Civics??? (importimage)
All I want to know is if 90-93 integra coilovers will fit on my 92 civic hatch/???
Old 07-26-2003, 03:43 PM
anyone!
Old 07-26-2003, 04:58 PM
Slow Egg's Avatar
yess
Old 07-26-2003, 05:46 PM
Default Re: Are 90-93 Coilovers Interchangeable with 92-95 Civics??? (turboXcivic)
As long as you are sure....thank you!
Old 07-26-2003, 06:51 PM
whoDAT's Avatar
it will definately fit. you just need to play around with those rubber o-rings in order for a snug fit.
Old 07-26-2003, 06:58 PM
Default Re: Are 90-93 Coilovers Interchangeable with 92-95 Civics??? (whoDAT)
Do you figure that the integra ones are just a stiffer spring rate than the civic ones?
Old 07-26-2003, 07:04 PM
whoDAT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importimage &raquo;</TD></TR><TR><TD CLASS="quote">Do you figure that the integra ones are just a stiffer spring rate than the civic ones? </TD></TR></TABLE>
yup!
Old 03-01-2012, 08:04 AM
Boost>n/a's Avatar
I got the same question i have a good deal on some ground control with koni yellow shocks but they are for a 90-93 integra and i have a 94 civic coupe. Will it fit my civic?? I need a answer before i order please help will be appreciated thank you
Old 03-01-2012, 08:41 AM
PHANTOM MENACE
24TEN's Avatar
http://lmgtfy.com/?q=90-93+integra+s...to+92-95+civic
You'll probably need to dig a bit deeper, but I know the answer is out there on the internet.
Old 03-01-2012, 12:39 PM
Boost>n/a's Avatar
Hopefully. Still been researching. All i got so far is by changing into da front forks to fit but idk
Old 03-01-2012, 03:48 PM
PHANTOM MENACE
24TEN's Avatar
That's the key. As far as I know that's the main thing you need is the matching front forks for whatever suspension you swap to.
ohsnapzafingcu
06-19-2006 08:59 PM
DriveSlowHomie
Suspension & Brakes
05-15-2005 05:24 PM
filthyCREX
11-28-2003 12:30 PM
Quick Reply: Are 90-93 Coilovers Interchangeable with 92-95 Civics???
