Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor?
If so what combination of axles could i put together? Im trying to swap a single cam back into my car but my 5 lug suspension is the 36mm kind.. Lmk what i could do.. TIA!!
Revised my origional post so its more clear
Ah here is the problem, i currently have a 5 lug conversion on my car, but it is the JDM Type R one which uses a 36mm Axle nut instead of a regular 32mm Axle nut. The only axle you are able to use is the JDM TYPE R axles which are the same thing as regular axles but they have a 36mm outer to fit the spindle correctly.
Now what im trying to do is figure out a way to keep my 5 lug suspension if i was going to throw a single cam inside my car.. the reason is because you cant use a b series axle for a single cam motor. Get it?
Modified by Mr. Tech at 11:58 AM 5/19/2006
Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (Mr. Tech)
u can swap out the outer parts of the axle to the 36mm or u can get some custom upgraded axles for your single that are 36mm. or just get a b series swap and use the itr 36mm axles
HT Order of Merit
Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">u can swap out the outer parts of the axle to the 36mm or u can get some custom upgraded axles for your single that are 36mm. or just get a b series swap and use the itr 36mm axles</TD></TR></TABLE>
Only the JDM ITR uses 36mm axles... all USDM models are 32mm, which is where the problem lies...
Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (JDM_Ej)
The problem also lies.. I dont think the 36mm outers will fit onto a single cam axle will they?
I am not really sure what your problem is but there is a company that sells 4 lug hup with 36 mm spline for the eg.
Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (c_buz)
be professional
The only real option you have is to try the 36mm outer CV onto a D-series axle (I don't know if it cant be done or not). If it doesn't work, you're SOL.
HT Order of Merit
Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (tofumonzter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">The only real option you have is to try the 36mm outer CV onto a D-series axle (I don't know if it cant be done or not). If it doesn't work, you're SOL.</TD></TR></TABLE>
I would agree with this. Get a junk SOHC axle and a 36mm outer and see if you can put them together.
Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Change the hub to a USDM ITR.</TD></TR></TABLE>
What's all needed to complete the conversion?
https://honda-tech.com/zerothread?id=818454
was not much help
Modified by tofumonzter at 10:54 AM 8/10/2006
was not much help
You can buy a ZC tranny. It uses b-series axles and works on single cams. I've never seen the hydro ZC tranny(I recently just heard of one) so I don't know if it uses the b-series axles, but I know the cable one does.
Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (92_VX_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_VX_EG »</TD></TR><TR><TD CLASS="quote">You can buy a ZC tranny. It uses b-series axles and works on single cams. I've never seen the hydro ZC tranny(I recently just heard of one) so I don't know if it uses the b-series axles, but I know the cable one does.</TD></TR></TABLE>
36mm outer joints do not work with d-series axles. ZC DOHC is rather rare but 94 JDM Integra SOHC used half shaft and b-series driveshafts as well, its fairly common.
easiest way is to get usdm or CTR 5bolt front or trade with someone who is going to do a k-series swap
Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (eg6ajk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote">36mm outer joints do not work with d-series axles. </TD></TR></TABLE>
even if i have an axle shop custom make me the whole thing if possible?
Go Tigers!
do this. get a zc differential (i have one) take your tranny apart, and do a differential swap. shim the differential so that it doesn't expletive up your bearings. and then get a d16a6 block and tap the threads and use the zc midshaft. AND THEN build the hybrid axles with the 36mm teg outer joints. DONE!
lol
lol
If you pay me the $50 you still owe me for the ARP rod bolts, I'll give you some solutions
Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (Em1Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Em1Kid »</TD></TR><TR><TD CLASS="quote">This guy is a lame Scammer </TD></TR></TABLE>
not to mention a douche with a 5 lug and a wicked sweet SOHC.
OG triple OG
Re: Any way to run a JDM ITR 5 lug with the 36mm axle with a SOHC Motor? (.Beaver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Beaver »</TD></TR><TR><TD CLASS="quote">not to mention a douche with a 5 lug and a wicked sweet SOHC.</TD></TR></TABLE>
nothing wrong with 5 lug and sohc!
Just an update...
Mr.Tech has sent me a pending Paypal eCheck refund today. Once this clears within about 3 days, he'll be taken off my black list and I'll rescind my gripes about our transaction.
Thanks for being responsible about this Mr. Tech
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">
Only the JDM ITR uses 36mm axles... all USDM models are 32mm, which is where the problem lies...</TD></TR></TABLE>
There is actually a US B-series 36mm outter joint, which can be found on the CRV.
Here's your options Mr. Tech:
1) I'm not 100% sure if this works, but you can try adapting 36mm CRV outter joints to the SOHC axles. If thats found incompatible, the next option would be...
2) Sell/trade your 98+ JDM ITR front spindles for that of US 5lug ITR spindles which accept 32mm outter axle joints. ....or...
3) purchase a set of US ITR 5lug hubs (32mm) and have your 36mm hubs pressed out of your spindles and have the 32mm hubs pressed in.
kazino42
08-31-2009 09:14 PM
