Which alternator will fit?
I have a 94 Civic with a second-gen JDM B16A. Recently when I start my car there is a squeak and whine that comes from the alternator. It's only for a few seconds and happens every so often. Is my alternator going bad? If so, what year alternator should I get to replace it? Will any DOHC alternator fit? Looked online and the 95 Del Sol DOHC is more expensive than a 99 SI alternator. Just trying to find the cheapest and most compatible alternator for my engine. Please let me know. Thanks!
Re: Which alternator will fit?
If you have a D series on hand, it can work, at least for a temporary fix. The upper bracket may need to be ground a bit on the upper lip of the channel the bolt slides in.
I did it, it's not the best solution, but it got me to work until my new alternator arrived.
aks for a 94 del sol with dohc vtec or try this
http://cgi.ebay.com/ebaymotors/INTEG...ehicleQ5fParts
yes it will work. you can take the old alternator off and they will cross reference the part number and it's the same. i've changed mine 3 years ago and i've had no problems.
so is there a difference between 90-93 integra, 95 Del Sol DOHC, or 99 Civic SI alternators? Would any of them fit on my jdm b16 with any problems?
