'99 Civic LX cracked exhaust manifold
Old 04-23-2009, 05:37 PM
dpkelly's Avatar
Icon2 '99 Civic LX cracked exhaust manifold
I found a crack in my exhaust manifold. Would you guys recommend a new one (single piece) or a two piece unit?
Old 04-23-2009, 05:43 PM
sp00ledbseries's Avatar
Default Re: '99 Civic LX cracked exhaust manifold
If your car is stock just get a oem replacement.
Old 04-23-2009, 06:04 PM
dpkelly's Avatar
Icon6 Re: '99 Civic LX cracked exhaust manifold
What about welding the crack shut?
Manifold with cat is expensive because Honda was stupid and made it a one piece unit.
Old 04-23-2009, 06:43 PM
freakasis's Avatar
just take it to an exhaust shop and get it weled...shouldnt cost more than $20
Old 04-24-2009, 06:13 AM
98greensi's Avatar
or find a d16y8 manifold/cat at scrap yard they usally dont crack like the y7 mani do
Old 04-24-2009, 06:44 AM
cjtimp's Avatar
Replaced mine w/aftermarket unit from Dorman products. Mine was part# 675-512. Came with all the necc. hardware and gaskets. Cost was $125....thought that was pretty fair.....
Old 04-24-2009, 06:45 AM
cjtimp's Avatar
Oh yeah....got it from O'Reilly Auto Parts..............shameless plug.....
Old 04-24-2009, 10:24 AM
dpkelly's Avatar
I'm going to get an aftermarket 2 piece unit. This way if the manifold cracks, I won't have to replace the cat.
A 'y8 won't do because it's a 4-2 manifold and the 'y7 is a 4-1 manifold unless I change out more of the exhaust system.
What a stupid design by honda.
Old 04-24-2009, 10:26 AM
raidacaipo's Avatar
x2
Old 04-24-2009, 11:08 AM
EL Vap133's Avatar
Convert it to the EX exhaust manifold and be done with it!
Old 04-24-2009, 01:26 PM
twiztid_989's Avatar
x2 that set up that honda did was dumb. I agree w el vap133 just go w ex exhaust manifold just go w ex exhaust manifold
Old 04-29-2009, 06:15 AM
dpkelly's Avatar
Icon2 Re: '99 Civic LX cracked exhaust manifold
I removed the old manifold last night. I know that sealing the manifold to the block is critical and so I bought a new gasket.
Is there anything I should put on the gasket/block/manifold mating surfaces to help seal it???
I do intend on cleaning the block with some brake cleaner.
Old 04-29-2009, 08:16 AM
EL Vap133's Avatar
The exhaust manifold gasket is enough, once you put it back on and drive the car for about a few days, tighten up the bolts/nuts again since they tend to loosen up.
Old 04-30-2009, 05:27 AM
dpkelly's Avatar
Thanks for the advice. I'll do just that. I installed it last night. No issues.
Old 07-23-2009, 02:10 PM
dpkelly's Avatar
Ok, the car runs great. However, the engine light came on and it's throwing a code 67 (cat. converter), damn OBDII!
Any ideas on what might be causing this?
Old 07-23-2009, 02:50 PM
B-outAteam's Avatar
U need a new o 2
Old 07-23-2009, 03:23 PM
hentai_11's Avatar
Originally Posted by B-outAteam
U need a new o 2
No he needs a cat! The secondary o2 sensor tests the function of the cat. Installing a new aftermarket header on LX and DX models eliminates the cat, hence the CEL its throwing is saying the cat function is bad.
A good way to fix this and keep it stock obd 2 is to get the cat and mid pipe from the EX model civic 96-00, but i guess in canada its called the "Si" model?
Old 07-24-2009, 05:28 AM
dpkelly's Avatar
The aftermarket manifold had the CAT inside of it. I'm going to check for exhaust leaks around that area.
Old 08-02-2014, 07:31 PM
zory1993's Avatar
I have a 97 Honda civic 1.6l sohc d16y8 and I have a cracked exhaust manifold. Do I have to replace my cat. At the at the same time on that year? Is it on piece? PLEASE HELP!
Old 08-02-2014, 07:37 PM
shotoutacc0rd's Avatar
1. You should have made a new thread
2. Your reading comprehension is lacking. This thread is for the non-vtec engine which has a 1 piece manifold and cat. You have the vtec engine which came equipped with a two piece manifold/cat, the way it should be.
I recommend going to a local junk yard and getting a used part.
Old 08-02-2014, 07:44 PM
zory1993's Avatar
Ok thanks a lot. Advance auto parts told me it was the d16y8 motor.
Old 08-02-2014, 07:54 PM
look under the hood, next to the exhaust manifold there's a block stamp. Reiterate what your car says right there.
while you're doing that, look at your cracked exhaust manifold. For your car, there should be a main piece that bolts to the engine. The 4 pipes should combine into 2. Then that should bolt to another piece, where the 2 pipes combine into 1. Then this piece should bolt into the cat.
you may need to take off a heat shield thingy, like 3 bolts.
infact, try and take some pictures of the crack and the whole thing. Upload them to a site like imageshack or photo bucket whatever and then link the pictures to YOUR OWN THREAD.
Old 08-02-2014, 08:21 PM
zory1993's Avatar
Ok thanks a lot!
94 IntegraLS
06-21-2011 06:17 AM
Battle2.0Eg
Honda Civic (2001 - 2005)
09-30-2010 11:39 PM
GiMpInThaCiv
03-21-2006 08:46 PM
wolfriley
11
03-19-2004 01:27 PM
Quick Reply: '99 Civic LX cracked exhaust manifold
