99-00 civic radiator support question
Old 09-04-2014, 02:06 PM
stevevang's Avatar
Default 99-00 civic radiator support question
Just a quick question, is the 99-00 civic radiator support a direct bolt on for 96-98 civics?
Old 09-04-2014, 02:24 PM
98ekb18c's Avatar
Default Re: 99-00 civic radiator support question
No. The radiator support is welded in.
Old 09-04-2014, 02:45 PM
stevevang's Avatar
Alright, thanks a lot!
Old 09-04-2014, 02:49 PM
ESQuireMyke's Avatar
You can replace it but requires welding. If you are doing this make sure you mock it up and all your body panels line up before welding.
Old 09-05-2014, 01:39 AM
slowcivic2k's Avatar
You will need to break the welds on the old core support and braze/weld them in. The 96-98 have different head lamp spacing. It is possible to use either of them interchangeably, but you will need to modify the head lamp mounting points a bit to make them truly bolt-on.
4thgenx42
11-09-2006 04:47 PM
jdmekB18C
10
05-23-2005 10:21 AM
carlton585
04-16-2005 07:10 PM
ninety-five_DB
08-26-2004 10:34 PM
DeliveryM2n
12
02-04-2004 11:52 PM
Quick Reply: 99-00 civic radiator support question
