98 honda civic dx dies when i slow down
Old 08-10-2004, 10:18 AM
xfrankix's Avatar
Default 98 honda civic dx dies when i slow down
Okay iv got a problem, I have a 98 honda civic dx 5spd with 67k miles. The problem is when i slow down or come to a stop my cars dies. (the battery light then oil light will come on then my car will die). This problem has no pattern at all like one day it did not even happen at all but then other days any time i slow down my car would die. Please help thanks.
Old 08-10-2004, 10:20 AM
Revolver's Avatar
Default Re: 98 honda civic dx dies when i slow down (xfrankix)
There is already a post about this...
Old 08-11-2004, 12:03 PM
xfrankix's Avatar
Default Re: 98 honda civic dx dies when i slow down (Revolver)
where is it?
Old 08-11-2004, 12:15 PM
soundbomber's Avatar
check the backup fuse
Old 08-11-2004, 03:08 PM
mika's Avatar
Default Re: 98 honda civic dx dies when i slow down (soundbomber)
what backup fuse?
Old 08-11-2004, 03:36 PM
Default Re: 98 honda civic dx dies when i slow down (mika)
the fuse under your underhood fusebox that says "backup", check it and see if it's blown
Old 08-11-2004, 03:42 PM
SprayinCX's Avatar
mine had this problem. i fixed it by adjusting the idle air screw. also try cleaning your injectors.
Old 08-11-2004, 03:55 PM
murmur9's Avatar
Yea, my car use to do that!!!!! So since it like to do what it wanted...i took that bitch out of my car and put in an engine that would do what I wanted. lol ******* pansy Honestly i think its either the fuel ...its def not the dizzy or anything. no tranny....try fuel pump, injectore and filter...
your car will start right back up though...right? (mine did that, i would come off the high way...and it would die when i stopped....but always started right back up.) maybe like the guy said...its your idel screw...maybe your idel is WAAYY down. mine would go all the way tro like only 250rpms when i would stop and then just die...and lights would come on.
Old 08-11-2004, 04:01 PM
Daniel's Avatar
Default Re: 98 honda civic dx dies when i slow down (SprayinCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SprayinCX &raquo;</TD></TR><TR><TD CLASS="quote">mine had this problem. i fixed it by adjusting the idle air screw. also try cleaning your injectors.</TD></TR></TABLE>
Yeah, try raising the idle. My Y8 did this, too, immediately after adjusting my valves. EXACT same symptoms as you're experiencing. Turned out the valve lash was way too tight. So I had to readjust them and redo the idle, and all was well.
Old 08-11-2004, 04:29 PM
Sinista's Avatar
Default Re: 98 honda civic dx dies when i slow down (Daniel)
first check ur battery, if you have a volt meter or DMM check the surface discharge...ur battery may be dirty, clean it from the top, check the water level, make sure its 3/8th full if it is, don't add anymore water it doesnt need to be filled to the top, if u do need water, used distilled water and not regular tap water. Also check if theres any corrosion on the ground and positive wires, u may have to replace those...if theres any corrosion on the battery posts brush it off with a wire brush or sand paper. If u done all this and still have a problem, u need a new battery, battery only last about six years or less before they have to be replaced no matter how *hi-tec* ur battery is....
Old 08-11-2004, 04:30 PM
ej1 pilot's Avatar
Default Re: 98 honda civic dx dies when i slow down (Sinista)
do you take it out of gear?
Old 08-11-2004, 04:36 PM
wdskuk's Avatar
Default Re: 98 honda civic dx dies when i slow down (Art In Motion)
Mines would only do that after I reset the ecu or disconnect the negative side of the battery. But after driving it for a few miles it becomes normal again. Never died on me again.
Old 08-11-2004, 05:18 PM
Kwisatz Haderach's Avatar
Default Re: 98 honda civic dx dies when i slow down (wdskuk)
Like most people have said, check your idle. But also check the IAC valve, it might be sticky or worn out. My car had the same symptoms as yours after I hadnt driven it for a couple months. New IAC valve and the problem was solved.
Old 08-11-2004, 07:53 PM
I'm really 2slow
2fast4u831's Avatar
that happened to me too. low idle and turned it up a notch
octodigitus
31
06-25-2013 08:08 PM
98DXCivi
07-14-2011 09:23 AM
atlballazz06
12-10-2010 04:18 PM
Poiquiop
03-04-2006 07:06 AM
ZUL8R
06-09-2004 10:55 AM
Quick Reply: 98 honda civic dx dies when i slow down
