98 hatch - wipers won't shut off unless I remove the fuse or unplug the switch
Old 12-01-2010, 05:16 PM
lshatch98's Avatar
Icon2 98 hatch - wipers won't shut off unless I remove the fuse or unplug the switch
i got in a wreak(front driver corner) and im in the process of rebuilding and my wipers will no shut off unless i pull the fuse. fuses are fine. no frayed wire from what i can see. this happened during/right after i noticed my wipers wouldnt turn off. any ideas?
car: 98 hatch
WIPERS ARE STUCK ON A LOW SETTING.
Old 12-01-2010, 06:03 PM
Former User's Avatar
Default Re: wiper problem
Do the wipers run at high or low speed?
Creating the best thread title helps you get more responses by letting members know what specific information is needed:
https://honda-tech.com/forums/showpo...12&postcount=1
Thread title edited.
Old 12-01-2010, 06:31 PM
lshatch98's Avatar
Default Re: 98 hatch - wipers won't shut off unless I remove the fuse
sent pm^ thanks for the title edit. i didnt really know what to put.
Old 12-01-2010, 06:32 PM
Linked's Avatar
were they high or low?^^^
wiggle the wiper switch and see if it stops
Old 12-01-2010, 06:38 PM
lshatch98's Avatar
wipers are on a LOW setting.
Old 12-01-2010, 06:42 PM
Is the accident damage near the wiper motor?
The wiper motor receives constant voltage and the wiper switch controls ground for the voltage. The low speed wiper motor is grounded by a blue wire (terminal #2 in the connector). Unplug the connector and check whether terminal #2 in the 5P connector has continuity to body ground. This test is done with the wiper switch off. Also trace the blue wire from the connector in an attempt to locate any damage.
Old 12-01-2010, 06:46 PM
lshatch98's Avatar
yes it was directly where the wash fuild bottle would be(i didnt have on) but the contector was ripped off in the accident
and will a digital volt meter work for the test? i have a blue point digital one.
Old 12-01-2010, 06:52 PM
Set the multimeter to read continuity (if you have this setting) or resistance on a low scale like 20 or 200 Ohms. Touch one probe to terminal #2 in the 5P connector and ground the other probe to a clean metal part of the chassis. If you read around a 100 Ohm or less, then you have a short in the blue wire.
Old 12-01-2010, 07:01 PM
lshatch98's Avatar
will do tomorrow and will post results...thanks alot Ron J. wish i would have posted earlier
Old 12-01-2010, 07:06 PM
lshatch98's Avatar
while doing these test is it in key on engine off?
Old 12-01-2010, 07:09 PM
Key is off. Wiper switch is off. You could even disconnect the battery to be safe.
Old 12-01-2010, 10:49 PM
lshatch98's Avatar
if the battery is disconnected how will the test work?
Old 12-01-2010, 11:52 PM
Solster's Avatar
Power is not need as your not looking for power.
Your looking for a connection between the blue wire and the Body ground.
the wiper motor will have 12V to it all the time and the blue wire provides a ground for the motor to work.
when you turn the wiper switch on low(when thay work corectly) the switch connects the blue wire to body
ground and there by compleating the circut and and powering up the wipers.
also take the steering columcover off and unplug the wiper switch to see if teh test results change.
if the meter reads 0.00 ~ 100.00 Ohms with the wiper switch pluged in
and you get "OL" (Open Lead) on the screen with the wiper switch Unpluged
then it would be safe to say you wiper switch is bad and you need a New one.
depending on how you got into the crash you may have hit the swich with some thing hard and done damage to it.
also i have a bluepoint meter and i haven't seen one that didn't have Ω (Ohms) setting
Old 04-13-2011, 11:21 AM
lshatch98's Avatar
well i replaced the switch an motor.....an im still having the same problem....im completely lost now.
Old 04-13-2011, 11:33 AM
You are lost because you refuse to do any electrical tests. What will you randomly replace next?
For example, if you unplug the wiper switch, do the wipers still run?
Old 04-13-2011, 12:14 PM
lshatch98's Avatar
the parts were free thats why replaced them
Old 04-13-2011, 12:18 PM
Electrical test results?
If you unplug the wiper switch, do the wipers still run?
Old 04-13-2011, 12:28 PM
lshatch98's Avatar
and it stops when the switch is unplugged....now when i plug the switch back in the wipers are stuck on high instead of low.
Old 04-13-2011, 12:32 PM
lshatch98's Avatar
and it does that with both new and old switches^
Old 04-13-2011, 12:36 PM
This^ is almost surely a switch problem.
Was the replacement switch new or used?
Do any terminals in the switch connector (male and female sides) look damaged?
Do you mean stays on high and stops when the switch is disconnected?
If so, carefully inspect windshield terminals 2 and 5 on both the switch and wire harness sides.
Old 04-13-2011, 12:49 PM
lshatch98's Avatar
the switch when its unplugged the wipers are off. when i plug it back in no matter what setting its on its on high. the only way to shut them off is to unplug the switch. it only started today before i could control the wipers and it would only go on and off int.
Old 04-13-2011, 12:52 PM
If both the old and new switches act exactly the same, then inspect the wire harness connector terminals I mentioned in my last post.
Old 04-13-2011, 12:55 PM
Also test the switches:
Old 04-13-2011, 01:19 PM
lshatch98's Avatar
Default Re: 98 hatch - wipers won't shut off unless I remove the fuse or unplug the switch
are the wire diagrams the same for the cx and dx hatch?
Old 04-13-2011, 01:23 PM
lshatch98's Avatar
ok my terminal goes
1234
56-8
Quick Reply: 98 hatch - wipers won't shut off unless I remove the fuse or unplug the switch
