98 floor harness and gas tank question
my 99 dx has a 98 hx motor swap in it including the hx floor harness.... i was wondering if using the 98 hx floor harness on my 1999 dx is going to cause my sensors in the gas tank that regulates fuel pressure to mess up..... or cause it to not work properly or cause the valves that open for gas vapors to mess up......according to majestic numbers. the components in the gas tank differs from 98 and 99,... diff part numbers.... all the plugs go in though
Re: 98 floor harness and gas tank question
according to the service manual, 96-98 gas tank vents gas fumes into charcoal canister over the driving period as pressure builds up in the tank
, and 99-00 has the ORVR system in the gas tank. which vents gas fumes into the canister while pumping gas.....
my theory is... the 98 hx ecu that i am running is not compatible with the sensors and components in the 99-00 gas tanks EVEN THOUGH they plug in perfectly, which will cause it to not vent any gas vapors into the charcoal canister or potentially leaving air pockets or something.. again.. theory....
94 IntegraLS
29
01-16-2012 05:36 PM
curioso
10
10-18-2010 06:55 AM
ACURA3.2TL
Acura TL, RL & ZDX
11-30-2007 08:02 PM
rhgindc
04-04-2007 09:47 AM
