98 Civic wont start
Old 02-21-2013, 12:50 PM
Johannes civic's Avatar
Icon2 98 Civic wont start
Engine (gas) is 1,4i, made in japan for the european marked.
Engine just stopped, tried for long to get it started but no luck.
In fact it did acumulate gasoline in the intake manifold...
It cranks ok, but no spark.
Came to the conclusion that the ignitor was bad and replaced it.
Now there is spark but still no start.
I've also tried to replace main relay and ignition switch...
So where do I go from here????
Old 02-21-2013, 12:53 PM
pityocamptes's Avatar
Default Re: 98 Civic wont start
Are you getting fuel, after you fixed the ignitor?
Old 02-21-2013, 12:58 PM
I'm not sure. How to a test this in a good way?
Old 02-21-2013, 01:00 PM
Can you hear the pump prime?
Old 02-21-2013, 01:04 PM
Yes, the pump primes for about 5-8 sek.
Old 02-21-2013, 01:05 PM
Can I use a test lamp to check the injectors getting their signal?
Old 02-21-2013, 01:13 PM
Do the injector clips have battery voltage to body ground with the key in ON(II)?
Old 02-21-2013, 01:16 PM
I'l check. So there is battery voltage to the injectors when ignition is on?
Old 02-21-2013, 01:19 PM
Should be...
Old 02-21-2013, 01:25 PM
Battry voltage is present in the injector clips.
Old 02-21-2013, 01:29 PM
Is your spark weak or strong? Did you try starting it after you flooded the intake with gas? Or have you tried it later? If you pull a plug are they flooded with fuel, dry?
Old 02-21-2013, 01:37 PM
I'd say the spark is normal. I've tried to start after flooding.
The intake has been dried, plugs taken out, was moist.
Used a blower to blow through intake and exhaust via plug holes to get rid of gas.
Old 02-21-2013, 01:42 PM
Have you checked your timing? Possible it may have skipped a tooth or more?
Old 02-21-2013, 01:47 PM
Could be a timing issue, but i'm a bit pusseled it should happen at the same time as the ignitor goes bad.....
Old 02-21-2013, 01:57 PM
You sure you are getting an intense spark (should be white)? Did you pull the plug wires and maybe reverse them or get them mixed up? When you put the ignitor in did you pull the dizzy rotor/cap and make sure they are on correctly?
Old 02-21-2013, 01:58 PM
Any CELS?
Old 02-22-2013, 02:34 AM
I'll check the timing. Also I'd had to dismantle the regulator housing to replase a broken screw holding the ignitor. I think it's impossible to mount it 180 degrees wrong , but maybe not?
What does CELS mean?
Thanks a lot so far..
Old 02-22-2013, 06:08 AM
MercerSX's Avatar
CEL = check engine lights
Have you pulled the plugs and made sure the cylinders are not flooded with fuel?
Old 02-22-2013, 09:45 AM
The CEL was there until I replaced the ignitor. Code 15 I belive it was.
Plugs have been out, the cylinders are not flooded.
So I'll check the timing, double check plug cables if they can be mixed up.
Hope & pray there's something worong there.
But just now I've got a date with Johnnie Walker....
Turbo2374
04-23-2013 08:33 PM
evi1jester
01-19-2011 11:27 AM
mangodade
03-18-2010 05:30 PM
19integra91
03-15-2008 09:38 AM
h0axpunkstar
12-03-2004 07:58 AM
Quick Reply: 98 Civic wont start
