98 Honda Civic DX losing power
Old 06-23-2011, 05:56 AM
lisitpc's Avatar
Default 98 Honda Civic DX losing power
My 1998 Civic DX 5 Speed Manual is losing power. This is happening only occasionally and is inconsistent and unpredictable. All the gauges drop to zero and the accelerator does not respond. It does not appear to be related to load or temperature. The power comes back after a few seconds. The last time it happened it killed the engine but usually it does not.
Gas mileage has been slipping slightly lately.
This could be pretty dangerous if I was making a turn or something.
A google search shows a number of people having this problem, but nobody has posted a solution.
Thanks for any input.
Old 06-23-2011, 06:35 AM
StreetsideStig's Avatar
Default Re: 98 Honda Civic DX losing power
Have your battery tested. If it's fine, pull out your alternator and have that tested, as well. Autozone/O'Reilly's will test both for free.
Old 06-23-2011, 12:51 PM
lisitpc's Avatar
Thanks for you reply. The battery is about a year old, but I am going to have it tested anyway.
Wouldn't the alternator fail all at once? There are no issues with starting the car. This problem only happens when driving the car. I wonder if there is a way to test the alternator without pulling it out of the car.
Thanks again.
Old 06-23-2011, 01:07 PM
shogee's Avatar
Could be ur ignition switch, but sounds really wierd, something a failing switch can do. My switch is starting to fail and sometimes when I hit a bump the radio and accessories die, but if I lightly tap my keys everything comes back on again
Old 06-23-2011, 10:59 PM
fleabag's Avatar
repair all electrical grounds.. if that doesn't solve it, then you've got some damaged wiring somewhere, maybe main relay needs to be replaced.
Old 06-23-2011, 11:09 PM
JDMxTai's Avatar
Try cleaning IACV.
Does this happen when driving or while stopping?
Old 06-24-2011, 04:33 AM
lisitpc's Avatar
Originally Posted by JDMxTai
Try cleaning IACV.
Only while driving.
Old 06-24-2011, 07:23 AM
NACvicSi's Avatar
I had a 99 Civic that did this. It would just randomly lose all power, but mine would quite when I took it out of gear. Then I would wait a few seconds, put it back in gear, and continue on my way. It got to where it would happen EVERY day and only in the mornings.
Old 06-24-2011, 08:02 AM
Arthas's Avatar
My bet is the ignition.
I had the same problem but mine was with the actual cylinder where you insert the key. That would "unclick" and the car would turn off. I would have to put the key back to original spot or hold it in.
Old 06-24-2011, 12:08 PM
lisitpc's Avatar
Interesting but I never touch the key. I downshift because the car is in motion but the power just comes back by itself after a few seconds.
Old 06-24-2011, 01:36 PM
shogee's Avatar
Its worth a shot to replace the switch its not too expensive and pretty simple to replace
Old 07-11-2011, 06:44 AM
lisitpc's Avatar
A mechanic determined that the problem was the ground cable. I had them replaced, and so far the car has not had the symptoms again.
Old 06-15-2013, 12:48 PM
lisitpc's Avatar
Well, the cable grounds helped, but later it turned out to be a faulty Ignition Control Switch.
adams299
Audio / Security / Video
06-23-2017 12:36 PM
jmacsss
04-11-2014 07:57 AM
thurmondauto
06-09-2009 06:00 PM
jerrywidening
07-02-2006 03:04 PM
Quick Reply: 98 Honda Civic DX losing power
