97 Civic DX is having power loss problems
Old 08-04-2011, 06:11 AM
jestor21's Avatar
Default 97 Civic DX is having power loss problems
I have a 97 Honda civic DX. The car has 135k miles on it. When i put the AC/Heat on i lose power until i hit 2nd gear. The check engine light is not on and I have had the transmission and engine checked and there are no problems with either. I have done some research and everything i read say it could be the main relay or a short somewhere that is interfering with the fuel pump. But before i start ripping things out i would like to know if anyone has had this problem before and how they fixed it. As everyone knows trying to track down a short in the harness can be insanely time consuming. Any information anyone could provide would be greatly appreciated.
Old 08-04-2011, 06:17 AM
hyperblu's Avatar
Default Re: 97 Civic DX is having power loss problems
Clean IACV and full tune up.. Start from there...
Old 08-04-2011, 06:50 AM
jestor21's Avatar
I would agree but the idle speed is good and it only happens when the AC or Heat is on.
Old 08-04-2011, 07:45 AM
motegicivic's Avatar
Only AC should affect power not the heat, since the AC uses a lot of engine power. Are you sure it is heat as well, and the AC button is not on?
Old 08-04-2011, 07:48 AM
hyperblu's Avatar
IACV adjusts air intake when the engine is under load (ie ac is on). Takes 5 minutes to clean it and it should probably be done anyway. idle speed and the iacv are two different things... your plugs are probably shot and causing a lack of power in the low end...
Old 08-04-2011, 07:50 AM
I thought 96 and on no IACV's
Old 08-04-2011, 08:00 AM
hyperblu's Avatar
96 and below have fitv i believe... i know my 99 Si w/ b16a2 had an iacv on the back on the intake manifold... havent looked at my 97 cx hatch with a d16y7
Old 08-04-2011, 08:07 AM
Former User's Avatar
Correct. ALL 92-00 Civics have an IACV. Only 92-95 Civics also have an FITV.
Old 08-04-2011, 08:12 AM
Woops I confused them.
jasonb
06-07-2017 03:24 AM
jestor21
08-04-2011 05:12 AM
Quick Reply: 97 Civic DX is having power loss problems
