96 civic AT slipping Help?
Old 06-14-2007, 07:47 AM
Shingpumps's Avatar
Default 96 civic AT slipping Help?
My 96 ex trans. hessitates between all gears and is starting to slip more. Down shifting is sometimes rough. Transmission has trouble adjusting while going up hills. Read a couple threads about selinoids and other trouble shooting tips. Anyone got any idea's?
Old 06-16-2007, 08:01 AM
Shingpumps's Avatar
Default Re: 96 civic AT slipping Help? (Shingpumps)
Anyone?
Old 06-16-2007, 08:12 AM
bringmyownend's Avatar
check your fluid?
Old 06-16-2007, 08:23 AM
Shingpumps's Avatar
Default Re: (bringmyownend)
Yes. Looks clean, levels maybe a little high but otherwise fine.
Old 06-16-2007, 09:15 AM
bluelxfodo's Avatar
check your auto solenoids?
Old 06-16-2007, 09:21 AM
Shingpumps's Avatar
Default Re: (bluelxfodo)
Aight, I'll check the haynes manual on those, in case they don't give specific info could someone explain the specs?
Old 06-16-2007, 09:30 AM
suspendedHatch's Avatar
Default Re: (Shingpumps)
If your fluid level is too high you probably destroyed the trans. There's a particular way of checking the level. You have to drive it around up to operating temperature, then pull over on a flat surface and within a minute of shutting down the motor, wipe the dipstick and put it back in. If the level is too high or too low, it wont shift correctly and you'll burn it up.
Also you have to use Honda ATF.
You also have to check and adjust the line pressure every couple of years.
When you replace the trans, add a auto tranny fluid cooler to it.
Old 06-18-2007, 10:08 AM
Shingpumps's Avatar
Aight, i'll cheak that first. Thanks
CIVICTANK
10
05-25-2016 08:34 AM
ooopseyesharted
03-15-2008 04:24 PM
EgSalad
Acura TL, RL & ZDX
03-25-2007 01:29 PM
Quick Reply: 96 civic AT slipping Help?
