96 Civic hatch dx open trunk wire
Old 10-30-2013, 04:20 PM
pnwjdm's Avatar
Default 96 Civic hatch dx open trunk wire
i got a 96 civic dx hatch and my open trunk switch is not hooked up. its just there with one yellow wire. where do i hook it up to? i need it to hook up this ex trunk light i got.
Old 10-30-2013, 05:55 PM
pnwjdm's Avatar
Default Re: 96 Civic hatch dx open trunk wire
bump
Old 10-30-2013, 07:18 PM
dazebreak's Avatar
The cable? Pic?
Old 10-30-2013, 07:32 PM
pnwjdm's Avatar
theres nothing to take a picture of. just the open trunk switch with one wire. i need to know where does the open trunk switch hook up to
Old 10-30-2013, 09:16 PM
dazebreak's Avatar
Call it a cable. The lever is by your driver seat. The cable hooks to it, then runs to the hatch. The hatch has a latch. The cable will attach, nach.
The lock cylinder on the trunk uses a short rod.
Old 10-30-2013, 11:16 PM
Former User's Avatar
The wire for the hatch latch switch is Blu/Blk not yellow. And how damn hard is it to post clear pictures of your hatch latch and the loose wires? If you want help, put more effort into your thread.
Old 10-31-2013, 08:56 AM
pnwjdm's Avatar
guys im not asking about the opening cables. im asking about the open-trunk switch that makes the light turn on the dash when the hatch is opened. my switch isnt hooked up for some reason so that means the light never works.
Old 10-31-2013, 08:58 AM
You fail to grasp the obvious point that the switch is incorporated into the hatch latch. Effort?
Old 10-31-2013, 09:02 AM
pnwjdm's Avatar
it is not. ill upload a picture in 5-10 minutes.
Old 10-31-2013, 09:17 AM
pnwjdm's Avatar
Im talking about this switch
Last edited by Former User; 10-31-2013 at 09:21 AM. Reason: Fixed picture to display
See connector C768:
Old 10-31-2013, 09:24 AM
This^ is not a switch for the trunk light.
The trunk light switch is in the hatch latch. Open the hatch and look up to see latch.
Old 10-31-2013, 09:42 AM
pnwjdm's Avatar
Wow im confused now. Then what is that switch for? (the one i pictured?) and why isnt my open trunk light on the cluster not lighting up? the bulb is good
Old 10-31-2013, 09:49 AM
Test the cluster open-hatch warning light switch in the latch with a multimeter. Make sure the switch connector is plugged in.
Old 10-31-2013, 11:09 AM
By the way, the hatchback does not come with a stock "trunk" light. If you wish to install one, get power for the light from the Wht/Red wire in gray 14P connector C562 and for ground splice into the Blu/Blk wire at the hatch latch-switch connector.
cor4ey
02-11-2010 11:57 PM
mdjjdm1
03-31-2008 02:41 PM
iperez
03-28-2006 12:10 PM
Quick Reply: 96 Civic hatch dx open trunk wire
