'95 Honda Civic EX - cooling system hoses, got 'em all now?
Old 04-26-2008, 04:09 PM
Ohmster's Avatar
Default '95 Honda Civic EX - cooling system hoses, got 'em all now?
I have a '95 Honda Civic 2DR EX KA4AT. 140K miles, and get my parts from http://www.hondaautomotiveparts.com/. They are a very good place to get parts for my Honda, experience has shown. I know a car of this age will need some maintenance in order to be reliable and since this is my primary vehicle, I try to stay on top of it. I replaced both upper and lower radiator hoses so they would not break on me and the radiator overflow to reservoir hose. I did not change the heater hoses because I could not get at all of the clamps, the ones near the firewall were on the bottom and as fate would have it, blew a heater hose at a stoplight.
Poof! White steam billowing out of the hood and the temp gauge shot up to over H. I went through the red light and into the gas station and shut 'er off. Yep, heater hose blew right near the clamp. Luckily I had some tools, cut the hose close to the end and re-clamped it, and then filled the radiator with water and got home but then ordered all 4 hoses from Majestic Honda.
We put those all on last night and so now I have two new radiator hoses and all 4 heater hoses changed. Are there anymore hoses that have to do with the cooling system or any system that should be changed at this point? '95 Civic with 140K miles. My mechanic friend was pulling on a couple of very small hoses, clamped to some small steel pipes, size of the overflow hose, and was saying that there might be one or two of those that pass coolant water. If so, they should be changed but I am not sure about this, does anyone know if that is it for my hoses? 2 radiator and 4 heater hoses, plus the radiator overflow to reservoir hose. Are there anymore? Thanks for your time and help.
Old 04-26-2008, 06:18 PM
ke98248's Avatar
Default Re: '95 Honda Civic EX - cooling system hoses, got 'em all now? (Ohmster)
Sounds like you got them all.
Oh, wait there's these:
Old 04-26-2008, 07:52 PM
Ohmster's Avatar
Default Re: '95 Honda Civic EX - cooling system hoses, got 'em all now? (ke98248)
Shoot! This is what I got:
103363 003 1 HOSE A, WATER INLET No Color 18.07 12.65
Long hose from heater valve to front engine under distributor
20072 004 1 HOSE A, WATER INLET No Color 5.38 3.77
Little "S" shaped shorty from firewall to water valve.
103365 005 1 HOSE, WATER OUTLET No Color 12.73 8.91
Mid length hose from firewall to rear, top engine block. This is the one I broke.
103326 003 1 HOSE, BYPASS OUTLET No Color 8.03 5.62
Mid length U shaped hose, does a U turn out and back in again right near each other. Rear engine where lower radiator hose connects to the engine.
So what am I missing? In this picture here, WATER HOSE (2): http://www.hondaautomotivepart...82%29
I got #3. This other page is where I got #3, #4, & #5 is WATER VALVE.
http://www.hondaautomotivepart...VALVE
These are all from http://www.hondaautomotiveparts.com/. With these settings:
CIVIC
1995
2DR EX
KA4AT
(part)
What page is this picture from and what hoses carry water? This looks like WATER HOSE (2) but it is not, what page is this?
Ohhhhhh, you did not get this page from Majestic! Now I gotta figure out what hoses you found here that I missed. A little help here would go a long way fellow please. Looks like the WATER HOSE (2) page in the image. What hoses here carry water besides #3?
I only see 1,2,5, & 6. 1 & 2 are HOSE, ELECTRONIC AIR CONTROL VALVE. 5 & 6 are BREATHER HEATER. Are those the ones you mean, the breather heater hoses? They carry water and can break? Thanks for your help.
Product No. Illust.No. Reqd.Qty. Description
103323 001 1 HOSE, ELECTRONIC AIR CONTROL VALVE INLET
103324 002 1 HOSE, ELECTRONIC AIR CONTROL VALVE OUTLET
19984 004 2 CLAMP, WATER HOSE (21.7MM) (CHUO HATSUJO)
19994 005 1 HOSE A, BREATHER HEATER
103328 006 1 HOSE B, BREATHER HEATER
19444 007 8 CLAMP, TUBE (D12.5)
What did I forget?
Jon Petersen
47
08-14-2018 02:21 PM
Auxient
03-02-2018 01:08 PM
crazyhouse2011
10
02-11-2014 11:02 AM
lude98SH
03-24-2010 10:22 AM
Ohmster
04-21-2008 05:13 PM
Quick Reply: '95 Honda Civic EX - cooling system hoses, got 'em all now?
