95 Civic Si - fuel pump isn't coming on, main relay isn't clicking, no start
** Solved **
I did search, and there are a lot of threads(249) to go through, so I figured I would put this up while I skim. So here's the skinny:
I put a 95 B18C1 in my 95 Si. Easy swap and have done a couple of these. The car ran before I swapped it, but now the fuel pump isn't coming on. The main relay isn't clicking. I have an s300 plugged in and I'm pretty sure the ecu isn't getting power because it will not let me upload maps.
Here's what I've tested so far:
- main relay (good)
- ign. switch (good)
- two fuses, the 15 and 7.5 amp fuse underhood (good)
- one fuse, 7.5 amp under driver's dash (good)
Any advice would be awesome! Thanks.
- main relay (good)
re: 95 Civic Si - fuel pump isn't coming on, main relay isn't clicking, no start
Unplug main relay.
Turn key to ON(II).
In connector, jump pin 1 or pin 5 to pin 7. Does the fuel pump run?
Turn key to ON(II).
Okay, pin 1 to 7 runs the fuel pump with ign off. Pin 5 to 7 runs fuel pump in key ON(II). BUT, now when I plugged the relay back in and tried it again, the fuel pump runs, but the 'battery' light is blinking and the speedo is bouncing around.
And now the ecu turns on also. I was able to access the sensors. It says the voltage is bouncing around between 8v and 10v, but I put a multimeter on the battery and it is 12.4v
Re: 95 Civic Si - fuel pump isn't coming on, main relay isn't clicking, no start
Nope! It doesn't turn over or click. Thinkni should replace the battery?
So, I went to go record a video and it turned over and started! The only I did from the last time I tried what you suggested was: a) Put a charger on the battery and b) Put another ground strap on the transmission. I'm not sure which one solved the problem, but I'll take it.
wtfisvtec??
36
08-16-2023 07:31 AM
dubshack
07-11-2004 06:24 PM
