94 civic sedan - A/C doesn't work
i got a 94 eg 4 door as one of my DD and i've been driving around without AC (didn't have the tensioner pulley) so i found the pulley assembly finally and added frion well the clutch wouldn't engage on the compressor so i disconnected it and temporaraly ran a wire from the plug on the compressor to the positive side of the battery (just to engage the clutch to add frion) it blew cold as hell btw but obviously i can't keep the wire hooked up that way permanantly so i know it has to do with the plug or something my question is what and where does that one pluge actuallly go to?? i searched but don't understand the wiring diagrams at all so any help would be appreciated
Re: 94 civic sedan
yes system was empty and i had a gauge to show me how much i was adding and the previous owner ran the condensor fan to the actual cooling fan so now it's always on....i just have no clue what else to look for?????
Re: 94 civic sedan - A/C doesn't work
An empty system has generally filled with air. In this case, you need to add some refrigerant containing a leak detecting dye in order to pinpoint the leak location. Then recover the refrigerant, fix the leak, replace the receiver/dryer, deep vacuum the system for at least 2 hours, make sure the system holds vacuum (=no more leak), and then recharge with the proper weight of refrigerant and volume of oil. Have a shop do anything you can't.
mrongey
08-18-2011 08:24 PM
