94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams
#151
Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (BlueIntegraBoy)
ok. and where can i get an electronic VSS? bump on the diagrams I wired a 98 GSR cluster into my 93 hatch without a problem (only wire splicing)
#152
Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (90dmintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90dmintegra »</TD></TR><TR><TD CLASS="quote">ok. and where can i get an electronic VSS? bump on the diagrams I wired a 98 GSR cluster into my 93 hatch without a problem (only wire splicing)</TD></TR></TABLE>
Junkyard. Any one from a B-series or D-series should work.
#154
90-93 integra ls pinout
PIN...Wire Color...Wire Function
A1...Yellow/Red...Seat Belt Reminder Light
A2...Green/Red...Parking Brake Switch Light
A3...Green/Black...Hatch Open Indicator Light
A4...Green/Red...Low Fuel Indicator Light
A5...Yellow/White...Fuel Gauge
A6...Yellow/Red...ECM, Trans Control, Moduel TCM, Cruise Unit, VSS
A7...Red Gauge...Lights, Dash Light Dim
A8...Empty
A9...Red/Black...Gauge Lights
A10...Green/Yellow...Right Turn Signal Indicator
B1...Green/Blue...Left Turn Signal Indicator
B2...Red/Blue...High Beam Indicator
B3...Blue/Red...ABS Indicator Light
B4...Blue...Tachometer
B5...Green/Red...Door Open Indicator Light
B6...Yellow/Green...Engine Coolant Temp Gauge
B7...Black...Ground
B8...Yellow...Ignition Power
B9...Green/Orange...Malfunction Indicator (Ck Eng.) Light
B10...Black/Yellow...Charging Sysem
B11...White/Blue...Charging System (Battery) Light
B12...Yellow/Red...Low Engine Oil Pressure Light
C1...Red...Cruise Control Unit
C2...Red/Black Gauge Lights...Cruise Control Dimming Circuit
C3... Empty
C4...Empty
C5...Black...Cruise Control Ground
C6...Empty
C7...Yellow...Ignition Power for Cruise Control Unit
A8...Empty
B7...Black...Ground
C3... Empty
C4...Empty
C6...Empty
#156
any of you guys have any more pics of the ITR gauge installed in an eg, a much more cleaner one? im planning to do one on my car. thanks. (i saw the earlier pics)
#158
hey blue
i wired it up and everything works, but for some reason, I have to turn the dimmer switch down to get the guage lights to work, and even then, they're barely lit? And also, whenever I accelerate, my charging light will stay on. Any ideas on why this is happening?
#159
Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (SanSational)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SanSational »</TD></TR><TR><TD CLASS="quote">hey blue
i wired it up and everything works, but for some reason, I have to turn the dimmer switch down to get the guage lights to work, and even then, they're barely lit? And also, whenever I accelerate, my charging light will stay on. Any ideas on why this is happening?</TD></TR></TABLE>
Perhaps a grounding problem? Wouldn't know why the charging light would be on other than a problem with the alternator.
#160
I know this isn't the right forum but since you helped out...
http://i61.photobucket.com/alb...r.jpg
http://i61.photobucket.com/alb...3.jpg
http://i61.photobucket.com/alb...2.jpg
#162
hey man i see you know about alot of this. and i got a big problem, i wire a 00 civic cluster into my 92 honda civic and i followed your wire diagrams and everything works except the fuel gauge .. i tried repining the one that are empty and no nothing, help me out please. ASAP..thanks man.
#166
Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (94_HATCH)
I have the two HARD TO FIND blue integra plug harnesses for sale if anyone is interested, PM me.
#169
Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (112480)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 112480 »</TD></TR><TR><TD CLASS="quote">Here's mine: 98 UKDM Type-R Cluster 170mph!! in my 92 VX hatch
Nice choice.
Nice choice.
#172
Re: 94-97/98-01 Integra Cluster Into 92-95/96-00 Civic Wiring Diagrams (ssdiablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssdiablo »</TD></TR><TR><TD CLASS="quote">how do i know with PLUG its A,B,C,D ???? for the Eg and a 94 Integra Cluster</TD></TR></TABLE>
Uhh, scroll down the first post. There are pictures.
#175
I love my gsr cluster in my EK!! If blueintegraboy wanted to make a little money, he could make a kit for all the popular genertations. Hint-Hint. i would buy one
