93 EG Odd Popping/Creaking Noise
Old 01-15-2015, 08:34 AM
MatteBLK's Avatar
Default 93 EG Odd Popping/Creaking Noise
Well, this has me stumped, replaced both CV Axles, ball joints have no play. Outer tie rod looks fine, but on the right hand side anytime turning left or right and when applying breaks theres a creaking popping sound, recorded a clip for youtube, pardon the fact its looking at the right front LCA, just incase it was the rubber worn out, but in the video as you can see no bad movement.
Anyone got ideas? Doesn't sound like a top mount either..
The video:
Old 01-15-2015, 12:11 PM
MatteBLK's Avatar
Default Re: 93 EG Odd Popping/Creaking Noise
Bump?
Old 01-15-2015, 01:24 PM
Lil Gnome's Avatar
Ok, when you press the brakes, the noise occurs?
Check for play by:
Lifting the front of the car
Grab either left/right wheel @ the 12 and 6 o'clock position
Move back and forth
Also have someone apply the brakes while you're under the car or the area where the noise is occurring.
Old 01-15-2015, 08:34 PM
Hysterically Calm
TomCat39's Avatar
Your 93 is a CX/DX/VX/LX/EX/Si?
Hatch/Coupe/Sedan?
Stock or non stock?
Does your nondescript 93 civic have power steering?
Old 01-15-2015, 11:45 PM
I never narc'd on nobody!
NotARaCist's Avatar
Almost sounds like a bad joint on your tie rod ends. Have you inspected the boots for damage?
Old 01-19-2015, 08:15 AM
MatteBLK's Avatar
It looks as if the outer tie rod is slowly crapping out, could that be the popping noise possibly? Just never heard an outer tie rod doing that before... Not second guessing you or trying to sound like a smart ***, fixed many before but would be shocked lol. but no inners tie rods are fine, just now the noise is on the left now. Oddly enough it goes away in the rain lol.
Also greased up the sway bar poly bushings, and it seemed to of helped but I think thats because it quieted down the noise vibrating threw the car.
Old 01-19-2015, 08:19 AM
MatteBLK's Avatar
Hatch/Coupe/Sedan?
Stock or non stock?
93 EG Hatch. Fully non stock with manual steering, basicly a fully built autocross car.
Old 01-19-2015, 11:34 AM
NotARaCist's Avatar
Yeah, the way the outer tie rod (AKA tie rod end) attaches to the knuckle, it could make a popping noise if it were failing.
There's an easier way to figure this out, though. Find a friend. Get the front end on jack stands. Figure out which side the noise is coming from. Take the wheel off that side, have the friend turn the steering wheel back and fourth while you pinpoint the noise. Getting eyes on it is going to be the best way to figure it out, since there are multiple places that the same noise could be coming from.
93sedansleeper
Suspension & Brakes
09-28-2015 10:24 AM
CaptRexKramer
09-27-2014 05:39 AM
angrysmileyface
06-07-2012 02:11 PM
dfJDM
01-11-2011 05:15 PM
Quick Reply: 93 EG Odd Popping/Creaking Noise
