93 Civic ex- Master Brake Cylinder
So I started a rear brake swap to goto discs, but am starting to realize there is probably a lot more things to deal with other than the emergency brake cables. (1 set has wrong brakets and maybe the wrong size, the other is the wrong length). So anyhow I am thinking about just forgoing the idea and going back to drums. Anyhow since I was going to swap MC and Prop valve (Already done the mc and discovered the original mc was leaking) is there a problem using the larger MC on the car with the drum brakes and original prop valve?
Re: 93 Civic ex- Master Brake Cylinder
No, there is no problem. If you have everything that you need for the disc brake swap, it isn't too difficult to do.
