92-00 Honda Engine Swap Wiring Guide VTEC AND NON VTEC
Old 03-10-2015, 01:54 PM
  #151
Fish Twig
tony_2018's Avatar
Default Re: 92-00 Honda Engine Swap Wiring Guide VTEC AND NON VTEC
I think he's referring to the iat sensor picture.
tony_2018 is offline
Old 10-02-2015, 01:05 PM
  #152
ohemgiii's Avatar
sweet. i needed this!
ohemgiii is offline
Old 10-05-2015, 07:27 PM
  #153
setrockg's Avatar
very interesting thread with complete info and pictures
setrockg is offline
Old 12-01-2015, 12:51 AM
  #154
Jahrye's Avatar
New to the forums so excuse me if this has already been asked. (If it has, send me a link to that page)
But I have a 95 EG Sedan (DX) my D15B7 blew and I'm swapping a D16Y7 in. If there is anything I should know or any tips on this swap specifically, any help would be much appreciated!!
Jahrye is offline
Old 02-25-2016, 01:34 PM
  #155
fc34812's Avatar
Icon4 Re: 92-00 Honda Engine Swap Wiring Guide VTEC AND NON VTEC
Originally Posted by HondaPartsHero
THIS IS IN PROGRESS AND WILL CONSTANTLY BE UPDATED. I JUST POSTED HERE TO SEE WHAT IT LOOKS LIKE IN FINAL FORM. BARE WITH ME AS I WILL SLOWLY ADD SECTIONS. THANKS
92-00 Swap Wiring Guide for VTEC and Non-VTEC
Being around here and the scene for a bit I figured I’d try to compile one thread that would try to answer pretty much 95% of all questions concerning swap specific wiring for 92-00 Civics of all models. Mostly this will be B and D series engines as they are the most common swaps, as I’m not that familiar with too many H or F series specifics, however I’ll add some links to good write ups for these. Also I won’t include any K or J series either as they are bit out of my realm and there are some good write ups already concerning the swap in general. If you would like something added or need to correct me PM me instead of posting in the thread so we don’t clog it up too much. I wanted to do this because often times I end up posting the same thing to answer people and retype what I’ve answered in previous threads. I don’t know everything but I love to learn what I don’t know and put it out there for people to solve their problems and also for them to learn more as well. Thanks
Swapping OBD1 engine/ECU into OBD1 Civic
(note for all 92 Civics the VTEC is already ran on the shock tower to ECU harness so using an EX/SI 92-95 engine harness will make VTEC plug and play. See figure 5)
D16Z6/D15B(JDM)*/Mini Me using P28 ECU
*If your JDM D15B doesn’t have a VTEC pressure switch you will need to unscrew this bolt and thread in one from any 90-01 Civic/Integra/Accord (See figure 2)
DX/LX - D15B7
-Will need to wire up VTEC solenoid and VTEC pressure switch to the P28 ECU all else will be plug and play (See figure 1)
CX - D15B8
-Will need to wire up VTEC solenoid and VTEC pressure switch to the P28 ECU (figure 1). If your CX model is NOT 4 wire you will need to wire up the 3 additional O2 connections below to the ECU (figure 1).
VX - D15Z1
For VTEC wiring see above pic. For knock sensor and IAB wiring see above pic (if using the chipped P28 you won’t need to wire IAB or knock sensor). If your VX has 7 wires you will need to wire up to make it 4 wire (diagram here http://www.hybridautomotive.com/tech/o2/)
B16A3/B17A/B18C1/B18C(OBD1 JDM) using chipped P28/P30/P61/P72 ECU
EX/Si - D16Z6
VTEC is plug and play. For knock sensor and IAB wiring (figure 1)(if using chipped P28 IAB and knock sensor won’t need to be wired up). All else is plug and play.
DX/LX - D15B7
For VTEC wiring see above pic. For knock sensor and IAB wiring (see figure 1) (if using P28 you won’t need to wire IAB or knock sensor). All other wiring is plug and play.
CX - D15B8
For VTEC wiring see above pic. For knock sensor and IAB wiring (see figure 1) (if using the chipped P28 you won’t need to wire IAB or knock sensor). If your CX model is NOT 4 wire you will need to wire up the 3 additional O2 connections below to the ECU (figure 1). All other wiring is plug and play.
VX - D15Z1
Reuse VTEC solenoid and pressure switch wiring for plug and play. If your VX has 7 wires you will need to wire up to make it 4 wire (diagram here http://www.hybridautomotive.com/tech/o2/)
B18A(OBD1)/B18B in DX/CX/VX/EX using P74/P75 ECU/all chipped OBD1 ECU’s
LX/DX/EX - D15B7/D16Z6
Plug and play.
CX/VX - D15B8/D15Z1
Plug and play. For 1 wire CX models you will need to wire in the additional 3 wires for the 4 wire O2 (see figure 1). If your VX has 7 wires you will need to wire up to make it 4 wire (diagram here http://www.hybridautomotive.com/tech/o2/). All else is plug and play.
OBD2 engine/OBD1 ECU into OBD1 Vehicle
(note for all 92 Civics the VTEC is already ran on the shock tower to ECU harness so using an EX/SI 92-95 engine harness will make VTEC plug and play.)
D16Y8 using P28
EX/Si/VX - D16Z6/D15Z1
Mostly plug and play. VTEC plug and play. Knock sensor will not be used for the P28 ECU. The EX/Si/VX distributor will not bolt up to the Y8 head exactly. You can use it but not all legs will bolt up. To use the Y8 distributor you will need an OBD2A or OBD2B to OBD1 adapter harness. The intake air temperature sensor is not located on the intake manifold of the Y8’s so you will need to relocate your IAT sensor in the intake arm (figure 3) OR use the Z6/Z1 manifold which will bolt up to the Y8 head fine. Reuse the Z6 injectors as the Y8’s will not plug in correctly. For the VX you will need to use some EX/SI/DX injectors for similar Y8 flow rates. Also reuse the Z6/Z1 alternator as the Y8 uses a different plug style. CKF sensor by the crank on the Y8 will not be used tie it out of the way. For the VX model use the above instructions to convert the 5 wire O2 to 4 wire (diagram here http://www.hybridautomotive.com/tech/o2/).
LX/DX/CX - D15B7/D15B8
Mostly plug and play. Will need to wire up VTEC solenoid and pressure switch (figure 1). Reuse the DX/CX distributor as it will bolt up. To use the Y8 distributor you will need an OBD2A or OBD2B to OBD1 adapter harness. The intake air temperature sensor is not located on the intake manifold of the Y8’s so you will need to relocate your IAT sensor in the intake arm (figure 3) OR use the CX/DX manifold which will bolt up to the Y8 head fine. You can use the DX injectors as they are the same flow rate. For the CX you will want to get some EX/SI/DX injectors as they are a higher flow rate as the Y8’s. Also reuse the CX/DX alternator as the Y8 uses a different plug style. CKF sensor by the crank on the Y8 will not be used tie it out of the way.
B16A2/B18C1 (OBD2)/B18C5 using chipped P28/P30/P72
EX/SI/VX - D16Z6/D15Z1
Mostly plug and play. VTEC plug and play. Knock sensor will not be used for the P28 ECU but will for all others. To use the A2/C1/C5 distributor you will need an OBD2A or OBD2B to OBD1 adapter harness. The intake air temperature sensor is not located on the intake manifold of the A2 so you will need to relocate your IAT sensor in the intake arm (see pic). Reuse the Z6 injectors as the A2/C1/C2 will not plug in correctly. For the VX you will need to use some EX/SI/DX injectors for similar A2 flow rates. You will need to use an OBD1 B series alternator for plug and play. CKF sensor by the crank on the A2/C1/C5 will not be used tie it out of the way. For the VX model use the above instructions to convert the 5 wire O2 to 4 wire (diagram here http://www.hybridautomotive.com/tech/o2/).
DX/CX - D15B7/D15B8
Mostly plug and play. Wire up VTEC as pictured above. Knock sensor will not be used for the P28 ECU but will for all others. To use the A2/C1/C5 distributor you will need an OBD2A or OBD2B to OBD1 adapter harness. The intake air temperature sensor is not located on the intake manifold of the A2 so you will need to relocate your IAT sensor in the intake arm (see pic). Reuse the DX injectors as the A2/C1/C2 will not plug in correctly. For the CX you will need to use some EX/SI/DX injectors for similar A2 flow rates as the OBD2 injectors won’t plug into the OBD1 plugs. You will need to use an OBD1 B series alternator for plug and play. CKF sensor by the crank on the A2/C1/C5 will not be used tie it out of the way. For the 1 wire 02 CX model use figure 1 to convert the 1 wire to 4 wire.
B18B/B20B/Z(OBD2) using P75 ECU
EX/SI/VX/DX/CX - D16Z6/D15Z1/D15B7/D15B8
Mostly plug and play. For the distributor you will need to use an OBD1 B18 for plug and play or use an OBD2 LS dizzy with an adapter harness. Alternator will need to be OBD1 B series for plug and play. For EX/SI/DX you can reuse the EX/SI/DX injectors, for VX/CX find some EX/DX/SI injectors for plug and play. CKF sensor by crank will not be used. For 1 wire O2 CX models figure 1 instructions for conversion to 4 wire O2. For VX 7 wire O2 use above instruction to wire up for 4 wire (diagram here http://www.hybridautomotive.com/tech/o2/).
OBD0 engine into OBD1 vehicle using OBD1 ECU
B18A (OBD0) using P75 OBD1 ECU
EX/SI/DX/CX/VX - D16Z6/D15Z1/D15B7/D15B8
Mostly plug and play. The alternator will plug in as the OBD0 and OBD1 alternator plugs are the same. For injectors you will need to reuse the EX/SI/DX injectors and for CX/VX find some EX/SI/DX injectors and use those. The fan switch location is different for the OBD0 engine and is on the back of the block. You will have to rewire the fan switch from the thermostat housing of your engine to the back of the block. The wiring order doesn’t matter so you will need either some connectors from a junk yard or some way to wire it up to that location (see pics below). For VX 7 wire O2’s (diagram here http://www.hybridautomotive.com/tech/o2/) and CX 1 wire O2 use figure 1 to rewire for 4 wire.
OBD2 engine into OBD2 vehicle using OBD2 ECU (NOTE: YOU CAN NOT MIX 96-98 OBD2A and 99-00 OBD2B ENGINE AND DASH HARNESSES WHEN SWAPPING ENGINES INTO 96-00 CIVICS AS THE ECU CONNECTORS ARE DIFFERENT SEE FIGURE 11
D16Y8 using P2P ECU
DX/LX/CX - D16Y7
Mostly plug and play. VTEC solenoid, VTEC pressure switch and knock sensor will need to be wired in (Figure 6 for OBD2A, Figure 7 for OBD2B). Also the idle air control valve will need to be wire from 3 wire to 2 wire (Figure 6 for OBD2A, Figure 7 for OBD2B). The secondary O2 sensor wiring will have to be lengthened by using an O2 adapter if you are using an EX style catalytic converter. The intake air temperature sensor will have to be relocated in the intake arm somewhere as the Y8 manifold doesn't have a place for it (see figure 8).
HX - D16Y5
Mostly plug and play. Reuse VTEC solenoid and VTEC pressure switch. 5 speed models will have to wire up the knock sensor as the only models with knock are CVT's (see figure 6 as all HX models 96-00 are wired for OBD2A). 7 wire O2 will need to be wired to 4 wire (eastcoasthondas.com - eastcoasthondas Resources and Information.).
B16A2/B18C1/B18C5 using P30(OBD2A)/P2T/P72
EX - D16Y8
Mostly plug and play. Reuse VTEC solenoid, VTEC pressure switch, and knock sensor wiring. Secondary O2 may have to be extended if if doesn't reach. For B18C1 the IAB's will have to be wired on the P72 ECU (see figure 6 for OBD2A and figure 7 for OBD2B). The intake air temperature sensor will have to be relocated in the intake arm somewhere as the A2 manifold doesn't have a place for it (see figure 8). For B18C1 and C5 you can also convert over to the round style IAT and place the connector on the manifold (see figure 9 for plug style).
DX/LX/CX - D16Y7
Mostly plug and play. VTEC solenoid, VTEC pressure switch and knock sensor will need to be wired in (Figure 6 for OBD2A, Figure 7 for OBD2B). Also the idle air control valve will need to be wire from 3 wire to 2 wire (Figure 6 for OBD2A, Figure 7 for OBD2B). The secondary O2 sensor wiring will have to be lengthened by using an O2 adapter if you are using an EX style catalytic converter. The intake air temperature sensor will have to be relocated in the intake arm somewhere as the A2 manifold doesn't have a place for it (see figure 8). For B18C1 and C5 you can also convert over to the round style IAT and place the connector on the manifold (see figure 9 for plug style).
HX - D16Y5
B18B/B20B/Z using OBD2A P75 (the 00-01 P75 uses an immobilizer and is not a good choice due to this limitation)
EX/HX - D16Y8/D16Y5
Plug and play. For the HX the 7 wire O2 will need to be wired to 4 wire (eastcoasthondas.com - eastcoasthondas Resources and Information.).
DX/LX/CX - D16Y7
Mostly plug and play. The idle air control valve will need to be wired from 3 wire to 2 wire (Figure 6 for OBD2A, Figure 7 for OBD2B). The secondary O2 sensor wiring will have to be lengthened by using an O2 adapter if you are using an EX style catalytic converter.
The intake air temperature sensor will have to be relocated in the intake arm somewhere (see figure 8).
OBD1 engine into OBD2 vehicle using OBD1 ECU
D16Z6 using P28 ECU
DX/LX/CX - D16Y7
Mostly plug and play. VTEC solenoid and VTEC pressure switch will need to be wired in (Figure 1). Also the idle air control valve will need to be wire from 3 wire to 2 wire (Figure 6 for OBD2A, Figure 7 for OBD2B). The intake air temperature sensor will have to be relocated in the intake arm somewhere (see figure 8) or rewire the IAT to OBD1 style (Figure 9). The CKF, EVAP purge and secondary 02 will be eliminated. D16Z6 distributor will need an adapter. Use the injectors from the Z6 and remove the injector "clips" for plug and play (Figure 10). Reuse the Y7 alternator for plug and play or use an adapter if you don't have the alternator.
HX - D16Y5
VTEC will plug and play. The intake air temperature sensor will have to be relocated in the intake arm somewhere (see figure 8) or rewire the IAT to OBD1 style (Figure 9). The CKF, EVAP purge, EGR and secondary 02 will be eliminated. 7 wire O2 will need to be wired to 4 wire (eastcoasthondas.com - eastcoasthondas Resources and Information.).D16Z6 distributor will need an adapter. Use the injectors from the Z6 and remove the injector "clips" for plug and play (Figure 10). Reuse the Y7 alternator for plug and play or use an adapter if you don't have the alternator.
EX - D16Y8
VTEC will plug and play. The intake air temperature sensor will have to be relocated in the intake arm somewhere (see figure 8) or rewire the IAT to OBD1 style (Figure 9). The CKF, EVAP purge, EGR and secondary 02 will be eliminated. D16Z6 distributor will need an adapter. Use the injectors from the Z6 and remove the injector "clips" for plug and play (Figure 10). Reuse the Y7 alternator for plug and play or use an adapter if you don't have the alternator.
B16A2/B18C1/B18C5 using OBD1 P30
DX/LX/CX - D16Y7
Mostly plug and play. VTEC solenoid, VTEC pressure switch and knock sensor will need to be wired in (Figure 1). Also the idle air control valve will need to be wire from 3 wire to 2 wire (Figure 6 for OBD2A, Figure 7 for OBD2B). The intake air temperature sensor will have to be relocated in the intake arm somewhere (see figure 8) or rewire the IAT to OBD1 style (Figure 9). The CKF, EVAP purge and secondary 02 will be eliminated. For 96-98 Civics Use an OBD2 B series VTEC distributor for plug and play or use an OBD2A to OBD1 distributor adapter. For 99-00 an OBD2B to OBD1/2 distributor adapter and OBD1/2 B series DOHC VTEC distributor must be used. Use the injectors from the B series and remove the injector "clips" for plug and play (Figure 10). Use a OBD2 B series alternator for plug and play or an OBD2-1 alternator adapter.
HX - D16Y5
VTEC will plug and play. The intake air temperature sensor will have to be relocated in the intake arm somewhere (see figure 8) or rewire the IAT to OBD1 style (Figure 9). The CKF, EVAP purge, EGR and secondary 02 will be eliminated. 7 wire O2 will need to be wired to 4 wire (eastcoasthondas.com - eastcoasthondas Resources and Information.). Use an OBD2 VTEC distributor for plug and play or use an OBD2A to OBD1 distributor adapter. Use the injectors from the B series and remove the injector "clips" for plug and play (Figure 10). Use a OBD2 B series alternator for plug and play or an OBD2-1 alternator adapter.
EX - D16Y8
VTEC will plug and play. Knock sensor will need to wired in (Figure 1). The intake air temperature sensor will have to be relocated in the intake arm somewhere (see figure 8) or rewire the IAT to OBD1 style (Figure 9). The CKF, EVAP purge, EGR and secondary 02 will be eliminated. For 96-98 Civics Use an OBD2 B series VTEC distributor for plug and play or use an OBD2A to OBD1 distributor adapter. For 99-00 an OBD2B to OBD1/2 distributor adapter and OBD1/2 B series DOHC VTEC distributor must be used. Use the injectors from the B series engine and remove the injector "clips" for plug and play (Figure 10) or use the Y8 injectors. Use a OBD2 B series alternator for plug and play or an OBD2-1 alternator adapter.
B18A/B using OBD1 P75
DX/LX/CX - D16Y7
The intake air temperature sensor will have to be relocated in the intake arm somewhere (see figure 8). The CKF, EVAP purge, EGR and secondary 02 will be eliminated. Use an OBD2 B18B distributor for plug and play or use an OBD2A to OBD1 distributor adapter. For 99-00 Civic and OBD2B to OBD1 distributor adapter with either an OBD1 or OBD2 B18A/B distributor. Use the injectors from the B18A/B and remove the injector "clips" for plug and play (Figure 10). Use an OBD2 B series alternator for plug and play or an OBD2-1 alternator adapter.
EX/HX - D16Y8/Y5
The intake air temperature sensor will have to be relocated in the intake arm somewhere (see figure 8) or rewire the IAT to OBD1 style (Figure 9). The CKF, EVAP purge, EGR and secondary 02 will be eliminated. For 96-98 Civics use an OBD2 B18B distributor for plug and play or use an OBD2A to OBD1 distributor adapter. For 99-00 an OBD2B to OBD1/2 distributor adapter and OBD1/2 B series DOHC VTEC distributor must be used. Use the injectors from the B18A/B and remove the injector "clips" for plug and play (Figure 10). Use a OBD2 B series alternator for plug and play or an OBD2-1 alternator adapter. For the HX the 7 wire O2 will need to be wired to 4 wire (eastcoasthondas.com - eastcoasthondas Resources and Information.).
Figure 1 (OBD1 ECU Wiring)
Figure 2 (JDM VTEC solenoid)
Figure 3 (OBD1 IAT sensor in intake arm)
Figure 4 (OBD0 fan switch/OBD1 fan switch)
Figure 5 (OBD1 Shocktower harness)
Figure 6 (OBD2A hybrid pinouts)
Figure 7 (OBD2B hybrid pinouts)
Figure 8 (OBD2 IAT into intake arm)
Figure 9 (Round style IAT)
Figure 10
Figure 11
Hi I have a civic 94 si with Block Y7 and Y8 Head, but the vtec dont work , the ecu is P28, can you help me?
fc34812 is offline
Old 02-26-2016, 11:58 AM
  #156
I never narc'd on nobody!
NotARaCist's Avatar
Holy **** seriously? Can we get a clean up on aisle 7?
NotARaCist is offline
Old 03-22-2016, 08:28 PM
  #157
Peter Fliri's Avatar
Honda gurus help!!
I have a 92 DX
I want to use a 92 VX harness because it's mint and not hacked like mines and it has vtec pre wired problem well question really ... my pass side shock tower to ecu has 3 plugs vx harness has four... what's the fourth plug all about will it run my d16z6? Is it for 5 wire oem wideband?
Also I'm running a p28 d16z6 98 ex Trans in 92 DX shell
4 plug 92 VX Harness
3 plug 92 DX harness
Peter Fliri is offline
Old 04-07-2016, 09:50 PM
  #158
KingTerrence's Avatar
Quick question I just swapped my obd2 y8 into my obd1 93 eg8 dx I keep everything(dizzy,alt,etc) for pnp on obd-1 harness. I'm going to be running for now stock p28 and already ran my Vtec solenoid and oil pressure switch into cabin harness. Now what do I do in terms of the o2 sensors? I heard that p28 doesn't call for o2? Is that true
KingTerrence is offline
Old 04-21-2016, 09:14 AM
  #159
Rplperformance's Avatar
Anyone in the orlando area needs swap harness or swaps done come check me out 930 carter rd wintergarden fl 34787 guarantee lowest prices around. Conversion harness starting at 150 wire tucks starting at 200
3522726556
Instagram Rpl_performance_ryanbuilt
Sorry guys im just trying to promote my shop.
Hope you dont mind
Rplperformance is offline
Old 04-22-2016, 09:18 AM
  #160
lxrd_vtec's Avatar
I have a quick question,
So I'm putting my GSR motor into my 93 Dx hatch. I got the jumper harness and stuff to go from OBD2 to OBD1 but I can't get it to start . The motor came out of my 00 GSR shell and a few months prior to the swap, I bought a new dizzy, battery, and alternator, never had a problem starting . When the motor got into my civic , my mechanic was having trouble getting it to start and stay running . After testing my ignition components and such he believes that I need a new interior harness. Could that be the problem ? I'm just asking for some second opinions as this is my first swap and I've already dumped a good amount of money and it's just getting aggravating . For more specifics, I am now running a p30 ecu and we used the engine harness from the GSR (OBD2) so I believe we've retained the fuel injectors etc, could it possibly be the alternator? Cause I didn't buy an OBD1 alt or could switching to an OBD1 p72 ECU remedy my problem? Been trying to tackle this problem for two weeks. And these damn interior harnesses for my hatch are near impossible to find in my area (North Jersey). Thanks guy.
lxrd_vtec is offline
Old 04-28-2016, 03:36 AM
  #161
DasHondaMonsta's Avatar
So when I put a z6 head on a y5 block will I need different bolts? What head gasket should I use? Belt? I have a 99 hx(d16y5), 95 coupe (d16z6)
DasHondaMonsta is offline
Old 05-23-2016, 05:14 PM
  #162
@uton's Avatar
very nice thread.
@uton is offline
Old 07-01-2016, 08:29 PM
  #163
MeandOwen's Avatar
I have a 1999 Civic EX manual that I have taken the Y8 out of & replaced w/Y7 from a 1998 Civic LX auto. I'm leaving the manual Tranny in my car of course & using the wiring harness from the Y7. I have switched ECUs to match the Y7 & manual transmission. My problem is I'm not getting signal to my fuel pump. My 99 has the cabin harness by the ECU that is responsible for the signal to the fuel pump relay according to your diagrams but I do not see how I should go about fixing my problem because my plug is not being used at all. Sorry if my problem is obvious to many but I'm learning. I do not see where the FPR is marked on any of the plugs for the ECU that I'm using (P2E). The 99 came w/P2P. I've been looking at this thread all week & tonight I'm wondering what will happen if I just plug the cabin harness into the A slot of the car's original P2P computer. Please advise as to how to properly remedy my problem. Any help will be appreciated!
MeandOwen is offline
Old 07-02-2016, 06:11 AM
  #164
MeandOwen's Avatar
I forgot to mention I am receiving voltage to the battery pin of the FPR and to the ignition pin as well. If I run a jumper from the battery solder joint to fuel pump solder joint on the relay the car cranks & idles smooth.
Old 07-02-2016, 06:19 AM
  #165
MeandOwen's Avatar
I forgot to mention I am receiving voltage to the battery pin of the FPR and to the ignition pin as well. If I run a jumper from the battery solder joint to fuel pump solder joint on the relay the car cranks & idles smooth. I tried plugging the cabin harness into the original P2P ECU but this changed nothing. I have tried several different FPR's but this is not my problem. I believe it is a simple fix but I haven't been able to figure it out. Please advise. After reading this thread I know the solution is out there. If I have left out any pertinent info I am happy to offer it up but this is all I have so far.
Old 07-15-2016, 05:39 PM
  #166
9d2civic's Avatar
(note for all 92 Civics the VTEC is already ran on the shock tower to ECU harness so using an EX/SI 92-95 engine harness will make VTEC plug and play.)...
when you say this I am guessing one for a 1.6 motor will work as well as long as its within the 92-95 years with VTEC or does it half to be specific to a 1.5 motor. my car is a 1992 with a 1.5 manual tranny in it and I am putting a 1.6 D16Y8 with its original manual tranny out of a 2000 civic into it
9d2civic is offline
Old 09-13-2016, 07:43 AM
  #167
931.EM1's Avatar
I have a 99 Civic Si and the owner before me put in the b20b but took out the power steering. Now the rack and pinion went bad so i have to replace it but its gonna run to crap because i dont have the power steering running to it. Can i fit power steering back in it or is there a way to get a rack and pinion for my civic without power steering or what are my options?
931.EM1 is offline
Old 10-11-2016, 01:08 PM
  #168
willems50's Avatar
Hi everyone, I've got myself into a little situation. a few years back I picked up a bone stock 97 cx hatch (non vtec) d16y7 I believe. After the motor died, I brought my car to a swap shop and they put a b16a gen II into my car. I am not exactly sure what they would have had to do to make it run, I'm seeing everyone says that it's necessary to re-configure the distributer clip, alternator clip, add vtec wire into harness, injectors, etc. not sure exactly. Either way, the b16a runs perfectly fine in my 97 cx hatch, I am now putting the motor into a cleaner chassis.
I have picked up a 2000 Honda civic coupe siR (Canadian model) which would make that an American SI. The car has a blown motor so I want to put my b16a into this chassis. I've already completed the swap. everything is connected. I left the ECU for last. I go to plug it in and of course, there's 3 clips coming from b16a engine harness, and 1 clip from the cabin harness, they can't all plug into ECU obviously. And of course the car doesn't start.
So my question is, considering my b16a was running in an obd2 chassis, but does not start in the newer chassis, what do I need to do with these 2 ECU connectors? I'm assuming they need to be merged into 1. any suggestions would be helpful before I tow my car to a specialist.
Thanks
willems50 is offline
Old 10-13-2016, 12:28 PM
  #169
willems50's Avatar
You can re install your power steering pump, brackets, belt if they are missing and get the fluid lines to run to your rack & pinion if they are missing. Or you can buy a new rack and cap the openings with hydraulic cap fittings.
Old 10-17-2016, 02:48 PM
  #170
CoolBeansEK's Avatar
Awesome article this was one of my main concerns doing any type of swap thanks!!
CoolBeansEK is offline
Old 01-18-2017, 11:01 AM
  #171
Wil Beck's Avatar
Anyone got any info on wiring a jdm OBD2 d15b mini me with a y8 head? Putting it in my 98 ex that had a y8 originally, would I be able to use the original harness and p2p Ecu? I'm not too knowledgeable about ecu and wiring so any help is appreciated
Wil Beck is offline
Old 06-15-2017, 12:47 PM
  #172
9d2civic's Avatar
My swap was just done not long ago and here is what I done.. per help with reading your post I did alot of what you made mention to do.. my car is a 92 civic vx and did have a Z1 with a 5 speed, new motor was a 2000 Y8 and it came with its original 5 speed. I pulled the motor and trans complete to avoid alot of messing around and then dropped in the Y8 and its 5 speed as a complete unit to simplify everything as well... I swapped the Z1 intake manifold to the Y8 and used the Z1 altenator, To make it a little more easy on me I reused the original 92 Z1 wire harness so that all of my sensor plugs matched up and as you stated I did get a dizzy harness to adapt the Y8 distributor to the factory Z1 harness. Knock sensor was not used and the crank sensor wire was put off to the side. NOW my question is since my Z1 had the VTEC I hooked up the wires that came off of the original harness to the VTEC switch and Y8 motor and changed out the ECU to the P28-A02, is there anything else I need to do to it for the VTEC to work. So far the only engine light on is code 41 for the o2 sensor heater,, wierd since I put a new sensor in it so I will need to track down that issue
9d2civic is offline
Old 08-09-2017, 11:44 PM
  #173
Mike Vue's Avatar
Nice.
Mike Vue is offline
Old 09-23-2017, 11:14 AM
  #174
DiegoCux's Avatar
Thank you for the amazing guide.
DiegoCux is offline
Old 10-24-2017, 08:32 PM
  #175
Dallas Moffatt's Avatar
Sorry if this has been answered in this form but can I use a p61 ecu on my d16z6 I didn't see it on the list or I might have missed it engine is in a 93 civic dx
Dallas Moffatt is offline
Quick Reply: 92-00 Honda Engine Swap Wiring Guide VTEC AND NON VTEC
