Automatic transmission compatibility.
Old 07-30-2016, 03:08 PM
GPC91's Avatar
Default Automatic transmission compatibility.
Just curious if a 91 do series auto tranny will work on a 97. I know the 5 speeds wouldn't because of cable and hydro clutches but no idea if there is a difference in the autos and all info like this I have been able to find online so far is dealing with 5 speeds.
Just curious to know if I have a spare ornot for my girlfriends new civic
Old 07-30-2016, 05:56 PM
Needs to be About 20% Cooler
DieMaster's Avatar
Default Re: Automatic transmission compatibility.
no it will not. 91 is self hydraulic controlled with a cable from the throttle. 96-00 is computer controlled. you would throw a ton of check engine / D4 codes if you swap it out if it works at all. not worth it IMO.
Old 07-31-2016, 04:26 AM
Seagull Management
94EG8's Avatar
Nope, it needs to be the same as what came out, even the 3 different D-series engines that came in '96 - '00 use different transmissions that aren't compatible with each other.
too_much_hott
01-20-2015 11:54 AM
xkellyxveitx
03-22-2011 09:57 AM
1.5boosted
12-13-2007 11:13 AM
racingant
07-07-2005 08:15 AM
Btothe3rdDegree
03-12-2004 05:03 PM
Quick Reply: Automatic transmission compatibility.
