NSX Brake upgrade on EK Si
Old 04-11-2004, 01:45 PM
D.CACO's Avatar
Default NSX Brake upgrade on EK Si
I'm sure it's been done a BUNCH of times, so I was shocked when I couldn't find it in my search...
I have a set of 91 NSX front calipers and rotors, wanted to use them on our 97 EK (which we converted to 99-00 si spec suspension/brakes).
Anyone know where to find a good wite-up/thread on this conversion upgrade?
Thanks-
Dennis
Old 04-11-2004, 02:22 PM
slammed_93_hatch's Avatar
Default Re: NSX Brake upgrade on EK Si (D.CACO)
well if you have the 99SI setup you will just have to re-drill the rotor, to your 4x100 specs.
i personally don't like this option so i would try and find a rotor that is 11.1" i 4x100 form. i belive people say that there is an older VW carrodo(sp) that has 11.1 inch rotor with the same specs of the 91 nsx, ITR ect.
Old 04-11-2004, 03:20 PM
VWkila's Avatar
Default Re: NSX Brake upgrade on EK Si (slammed_93_hatch)
Well, here's an old thread on NSX to EH.
https://honda-tech.com/zerothread?id=191651
Old 04-11-2004, 03:22 PM
D.CACO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">well if you have the 99SI setup you will just have to re-drill the rotor, to your 4x100 specs.
i personally don't like this option so i would try and find a rotor that is 11.1" i 4x100 form. i belive people say that there is an older VW carrodo(sp) that has 11.1 inch rotor with the same specs of the 91 nsx, ITR ect.</TD></TR></TABLE>
Does the NSX caliper bolt right into the Si caliper mounting points? (I dont have the caliper here at the shop, otherwise I would check myself)
You're right, I have heard of VW or sumthin caliper that is 11.1 or so that fits for this swap. Anyone out there know for sure?
I agree with you, as Redrilling holes can be a recipe for disaster...
Thanks for the reply.
-Dennis
Old 04-11-2004, 03:24 PM
VWkila's Avatar
Yes, earlier Corrados had 4 bolts pattern that matches the Civics, though you'll need a hubcentric rings, cause the that part, Corrados are bigger.
Old 04-11-2004, 03:27 PM
well i have NEVER seen it BUT, since the every were i read that they do, there is a memember on here who has them on his teg and im pretty sure they bolted right up on his 5 lug hub
Old 04-11-2004, 04:03 PM
IS3Fifty's Avatar
Im assuming that you didnt pay a lot for the NSX rotors and calipers, right? I say this because I am wondering why you didnt just get something like a Rotora big brake upgrade.
Old 04-11-2004, 04:45 PM
D.CACO's Avatar
Default Re: NSX Brake upgrade on EK Si (TODAeg6)
This is a RR car that we are racing in Honda Challenge. Last race at Buttonwillow raceway, we torched the front pads (Porterfields best racing pads- R4) . The padding crumbled off the backing plate...
so, obviously our brakes are overheating and we need to run larger diameter (we are running 00-99 Si/powerslots right now.
Obviously racing is $$, and I have an extra set of NSX rotors/calipers from my 91 NSX. The only reason why I am considering using them is because one of the other cars in the series is running NSX setup in an EG, and his brakes seem to work great.
Basically, if we can save 1000 bucks, it's worth investigating, and I was thinking you guys in the forum could help me make a decision.
Otherwise, an Endless/Stoptech/Fastbrakes set is probably the best consideration. I have never seen Rotora's on a race car yet. (Only Drift car's/show cars and that is completely different)
*please don't turn this into a "these brakes are better" thread... I really just want to know how to do the NSX conversion, and see if it's worth the time...*
Thanks for the replies.
Old 04-11-2004, 05:36 PM
confidence's Avatar
the rotors your are looking for are from a VW corrado VR6
Modified by snail at 9:36 PM 4/11/2004
Old 04-11-2004, 06:15 PM
D.CACO's Avatar
Default Re: NSX Brake upgrade on EK Si (snail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snail &raquo;</TD></TR><TR><TD CLASS="quote">the rotors your are looking for are from a VW corrado VR</TD></TR></TABLE>
Thanks!
Anyone know of any negative performance issues that can arise from such a conversion? (trying to avoid incorrect/unsafe install)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VWkila &raquo;</TD></TR><TR><TD CLASS="quote">Yes, earlier Corrados had 4 bolts pattern that matches the Civics, though you'll need a hubcentric rings, cause the that part, Corrados are bigger.</TD></TR></TABLE>
Where can we get hubcentric rings/ how thick? etc...
Better yet- is there a step-by-step somewhere (with photos still posted)?
Thanks,
Dennis
Old 04-11-2004, 06:59 PM
im not aware of one but, search for NSX brakes and i think there is a post were a guy hypothosized that, the early NSX caliper has less clamping force then an ITR caliper. i dunno if it has been proven wrong ill search for it though
Old 04-11-2004, 07:04 PM
maybe usefull
https://honda-tech.com/zerothread?id=239844
here you go this is the post i was talking about
https://honda-tech.com/zerothread?id=293540
another helpfull post
https://honda-tech.com/zerothread?id=266731
Old 04-11-2004, 09:00 PM
D.CACO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">maybe usefull
Thanks for the links Slammed_93_hatch!
FYI, this is the info I got from Andrie, WCHC H1 fellow racer:
Andrie: The front caliper is a bolt on deal. The rotors is a bit tricky. You will need to get Acura Legend rotor (92-95) and redrill them to 4 bolts. In addition you will need to add 1.5mm spacers behind the rotors to push them out.
Hmmmmm....
Old 04-11-2004, 09:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D.CACO &raquo;</TD></TR><TR><TD CLASS="quote">
Hmmmmm....</TD></TR></TABLE>
hmmmm is right there is no way i would do that unless it was solid spacer, and then again i don't like the idea of redrillling the rotors
Jon777
Suspension & Brakes
05-26-2011 02:00 PM
blackcivic11
17
09-15-2008 07:25 AM
civictildeath
05-23-2005 01:49 PM
EK4door
02-19-2004 08:35 AM
b Team
08-06-2003 11:42 AM
Quick Reply: NSX Brake upgrade on EK Si
