40 offset???what does this mean
Old 02-08-2005, 07:18 PM
.Kevin.'s Avatar
Default 40 offset???what does this mean
I am currently looking at buying a set of rota grids and the guy said they are 40 offset...now I've seen wheels for a civic that are 43, 40, 42.. my question is what do these numbers mean and if you may know will the 40 offset fit a 4 lug 99 civic ex. thanks
Old 02-08-2005, 07:21 PM
civictildeath's Avatar
Default Re: 40 offset???what does this mean (Slow_CvC99)
it is how far the outer lip (where the tire meets the rim) sticks out past the center of the rim (area by lug nuts)
there are a few of these posts so search
Old 02-08-2005, 07:27 PM
.Kevin.'s Avatar
i tried the search i got a lot of people asking the offsets and if they will fit FWD and RWD cars...but as one said 40 should be ok i guess i will just go with it but i did want to know what it was...i kinda understand what u mean thanks
Old 02-08-2005, 07:32 PM
Kamin's Avatar
Default Re: 40 offset???what does this mean (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">it is how far the outer lip (where the tire meets the rim) sticks out past the center of the rim (area by lug nuts)
there are a few of these posts so search</TD></TR></TABLE>
the amount of lip is rim specific, offset has something to do with it but on alot of wheels a smaller or larger offset will not affect lip.
this is a good friend of mine's car. his rear wheel is a 17x9 and around a +12 offset (i could be wrong on these numbers)
as you can see there is virturally no lip to speak of, thats because of the rim design.
offset is a measurment of how far away from center the hub is.
0 offset means it is directly in the middle of the wheel. +32 means its 32mm away from the centerline of the wheel. etc etc.
here
http://www.discounttire.com/dt...s.jsp
Old 02-08-2005, 07:35 PM
Default Re: 40 offset???what does this mean (Kamin)
i stand corrected
*calls ******* that told me this incorrect info to bitch while he is sleeping
i apologize on me
Old 02-08-2005, 07:43 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">i stand corrected
i apologize on me</TD></TR></TABLE>
no worries
its a realy common misconception.
Old 02-08-2005, 08:03 PM
nojoke's Avatar
Offset is how far the hub mounting point of the wheel is from the center of the wheel.
For example, assuming the width of the wheel is the same, a +25mm offset on a Honda would make the wheel stick out past the fender line, and just look plain stupid.
On the contrast, if the offset was +60mm, the wheel would tuckand most likely rub the fenderliner and would almost be impossible to make a full turn.
aaronboy123
18
10-28-2009 07:13 PM
k4rts
09-12-2006 04:55 PM
articbluedc5
Honda Fit
05-15-2006 09:30 AM
All Motor Jew
26
02-23-2005 10:04 PM
Quick Reply: 40 offset???what does this mean
