2k Si, size of rear hub nut?
im swapping out brakes.
on my 2k Si, what size is the bolt that's holding the hub to the trailing arm??? I'm talking about the big bolt that sits on the back of the hub there, with 4 torx screws around it. Someone listed it as 19mm, but its not.
what size is it?
what size is it?
Re: 2k Si, size of rear hub nut? (yh23)
on the back of the trailing arm? If so,Just go and get an axle nut wrench if thats what you are talking about. Just dont forget to buy another one to replace it and then punch it into the axle again.
Re: 2k Si, size of rear hub nut? (mjrage)
nevermind, i found the specs....
and no, I could not measure it, don't have a metric ruler on me...
and no, not an axle nut wrench...the axle nut is 32mm.
the nut i was referring to is what connects the hub to the trailing arm. Its **24mm**
