205/55/15 on 99-00 Si Wheels
Old 04-23-2004, 05:09 AM
fast4w$'s Avatar
Default 205/55/15 on 99-00 Si Wheels
I'm lowering my girlfriends car, an 01 civic 2 door with Eibach prokits, and I am also installing Si's with 205-55-15 tires...Is this too large a fitment for this car? I think it will be ok, because I'm only lowering an inch, but i'm concerned about any rubbing...
Old 04-23-2004, 05:46 AM
The King's Avatar
Default Re: 205/55/15 on 99-00 Si Wheels (FaS4wS)
you should be ok with the prokit since it doesnt to an agressive drop , but a 205/55 is a rather tall tire , the reccomended size is a 195/55 or a 205/50 , but other than knowing that you should be ok
Old 04-23-2004, 05:47 AM
sohc_boy's Avatar
well the stock tire's a what 185-65-15? thats got a 24.5" dia and a 205-55-15 has a 24" dia so i think u'll be ok, although the 205 will be wider u might rub but with only 1" drop i'd think it would clear just fine.
Old 04-23-2004, 05:50 AM
The King's Avatar
Default Re: 205/55/15 on 99-00 Si Wheels (sohc_boy)
stock size is 195/55.r15 which came as a potenza re92 or michelens depending on where the car cames from
Old 04-23-2004, 05:57 AM
Quetzolcotl's Avatar
Default Re: 205/55/15 on 99-00 Si Wheels (ReDRoCkEt)
it will work fine. I dropped my car 2" with the same size rims. get 205/50's instead so the tire has less sidewall.
Old 04-23-2004, 05:58 AM
fast4w$'s Avatar
Well, the tire thats on the car now is 185/65/15...Thanks for the input fellas, I was a little concerned about any rubbing for the most part. I think it'll be ok. I'm interested to see the look of the car with the meaty tires installed...
Old 04-23-2004, 06:04 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FaS4wS &raquo;</TD></TR><TR><TD CLASS="quote">civic 2 door with Eibach prokits, Si's with 205-55-15 tires</TD></TR></TABLE>
Just to chime in and give you a little more confidence... I'm running the exact same setup on my 00 coupe, and have no clearance issues.
I rubbed once or twice with my wheel all the way cranked, and on a very steep slope while exiting my parking lot, but that's a pretty unique circumstance, so on any given day, you're good to go.
Old 04-23-2004, 06:41 AM
-Trinitron-'s Avatar
It will fit...the only 15 I have seen with rubbing issues was a Turbo Si running 255/50/15. I couldn't believe he got that tire on the stock rim.
Old 04-23-2004, 07:00 AM
Jon D's Avatar
YOu'll be fine man....that kit shouldnt present any problems because its not that aggressive of a drop as stated above.
Old 04-23-2004, 08:12 AM
fast4w$'s Avatar
Default Re: 205/55/15 on 99-00 Si Wheels (B18C-Rsi)
Great, thanks for the help guys. I'll let you know how things turn out!
Old 04-23-2004, 08:32 AM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDRoCkEt &raquo;</TD></TR><TR><TD CLASS="quote">stock size is 195/55.r15 which came as a potenza re92 or michelens depending on where the car cames from </TD></TR></TABLE>
wrong: its a 01 civic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_boy &raquo;</TD></TR><TR><TD CLASS="quote">well the stock tire's a what 185-65-15? </TD></TR></TABLE>
correct man stock tires on civic keep on getting bigger and bigger. at this rate, civics will have dubs standard in about the year 2020. anyways, decent "sport" tires dont come in anything taller than 55 series, so i'd go with a 205/55-15 also
miss.Soshinoya
01-01-2011 10:41 AM
jmayhew
05-01-2009 08:02 AM
EJ1chevelle
10-13-2007 09:39 PM
ohnoitsryan
05-26-2007 03:40 PM
mattdenali
05-25-2005 07:50 PM
Quick Reply: 205/55/15 on 99-00 Si Wheels
