2000 honda civic lx code p0420
Old 05-11-2008, 01:17 PM
tferro86's Avatar
Default 2000 honda civic lx code p0420
the code p0420 come out when i check my car with the ob2 it says input/turbine speed sensor A circuit Gear Ratio incorrect what is this and how can i fix it
Old 05-11-2008, 05:41 PM
hbboy07's Avatar
Default Re: 2000 honda civic lx code p0420 (tferro86)
are you sure its for a a speed sensor i think p0420 is a cat code
Old 05-11-2008, 05:47 PM
emergencybm's Avatar
po420 is cat efficiency below threshold bank 1 if thats the case its your cat or your secondary o2 sensor thats throwing it
Old 05-11-2008, 05:48 PM
h22civic88's Avatar
Default Re: 2000 honda civic lx code p0420 (hbboy07)
Yeah, a P0420 code is a catalyst efficiency below threshold code which is usually an o2 sensor issue....
Old 05-11-2008, 06:05 PM
Davus's Avatar
Default Re: 2000 honda civic lx code p0420 (h22civic88)
Beg to differ, I threw P0420 a few months back, went to muffler shop and got a stock-replacement-high-flow cat welded in, been gone since.
It usually indicates exactly what it says: That the catalytic converter is dead (mine was alllll burnt up after 240K miles!), not necessarily that the oxygen sensor is bad.
Old 05-11-2008, 06:18 PM
h22civic88's Avatar
Default Re: 2000 honda civic lx code p0420 (Davus)
I've had plenty of cars come in the shop and it was the o2 sensor, so everyone will encounter differences... I didnt say always, just I've had may fair share that the o2 was bad with that mil showing...
Old 05-20-2008, 07:13 PM
fsjcowboy's Avatar
My 2001 CRV threw this code after 139K miles. I replaced the cat with a NAPA factory replacement, the primary O2 sensor with a factory replacement, and the secondary O2 sensor with a Walker universal O2 sensor which I had to splice in because it had no plug (universal). After resetting the faults, the MIL continues with the code reading PO420. I suspect the universal sensor because the voltage reads either 0.00v or 1.25v....nothing in between. The voltage for the primary sensor bounces around from .120v to .720v, which I think is normal. I plan to replace the secondary universal sensor with an OE sensor. I'll follow up with my results after the ECM monitors reset .
bigjoncoop
12-18-2017 07:47 AM
Peteandsandy
Honda CR-V & Element
12-10-2017 05:49 PM
2stroke1971
08-09-2016 03:33 PM
danteisme
03-16-2005 07:01 AM
Quick Reply: 2000 honda civic lx code p0420
