2000 civic si no start
#51
#53
Re: 2000 honda civic si no crank
Well since the switch is way up in the dash i followed the wires and cut them. Wrapped both black wires around one of multimeter lead and both blue on the other lead.
#54
The clutch pedal starter switch has only two wires: Blu/Blk and Blk.
If you cut the wires off the switch connector, then the pedal should have no effect on the voltage readings.
#55
I know. I followed them and they go directly under the steering column. I cut both the blue/black and black between the switch and where they enter the wire harness. I then connected the black lead from the switch and the harness to the negative multimeter lead. Same with the blue/black wire only to the positive multimeter lead
#56
#57
Cutting the wires seems a bit drastic. You'll need to repair them now. When you do, move to the starter and test whether battery voltage reaches the solenoid wire with key in ON(III) and pedal depressed.
#58
#59
Don't know what you mean by signal, so let's be unambiguous and call it the solenoid wire.
#60
#62
#63
You need to learn as we move along. Two (+) wires and no/zero/zilch ground wires attach to the starter. The Blk/Wht wire is for the solenoid. You should be reading battery voltage there. The fact that you're not reveals the problem.
#64
So since its not reading battery voltage then its my ignition right?
#65
Unplug connector C101 and measure voltage at pin 9 (Blk/Red wire) of the female side connector with the key in ON(III) and the pedal depressed. What's the reading?
#66
#68
#72
