2000 Civic DRL system - Two cables
Old 10-30-2015, 03:40 AM
Uzumymw's Avatar
Default 2000 Civic DRL system - Two cables
Hello, I'm during installation DRL Canada system into my 2000 Civic LS.
I used the manual:
but I can't find where I should connect the wires BLK/WHT (no. 20) and YEL/BLK (no 18) to the fuse.
I found only one connector C419 for YEL/BLK wire but I'm not sure whether it's fine connector?
And what about BLK/WHT cable?
Old 10-30-2015, 07:30 AM
Fish Twig
tony_2018's Avatar
Default Re: 2000 Civic DRL system - Two cables
There's more than one connector to the fusebox, have you check those?
Old 10-30-2015, 10:20 AM
Uzumymw's Avatar
I know there're many of connectors. I'm looking for a suitable for connect these 2 wires, but manual can't help me :/
Old 10-30-2015, 12:07 PM
Fish Twig
tony_2018's Avatar
In order to make it look like factory you need it to be pinned into the correct plug in order for you to put a 10a fuse in slot 20. Thats why you need to look at all of the plugs in order to locate the correct one.
Old 10-30-2015, 12:11 PM
Uzumymw's Avatar
I thought that I wouldn't have to do this. Maybe someone install DRL and is able to help me?
Old 10-30-2015, 07:00 PM
Former User's Avatar
The two wires pin to connectors C419 (pin 9) and C420 (pin 16).
Old 10-31-2015, 01:16 AM
Uzumymw's Avatar
Wow, I don't know why I didn't found this :O
THANKS!
Old 10-31-2015, 04:50 AM
Fish Twig
tony_2018's Avatar
Download the FSM.
Old 10-31-2015, 06:31 AM
Originally Posted by tony_2018
Download the FSM.
I think he has the manual but hasn't yet figured out where everything is.
Old 10-31-2015, 07:06 AM
Uzumymw's Avatar
Old 10-31-2015, 09:25 AM
Fish Twig
tony_2018's Avatar
he was able to locate the diagram for the DRL and one of the connectors behind the fusebox. They are there, I'm trying to not deter you from continuing your search because that info is in the FSM.
Old 10-31-2015, 10:22 AM
Uzumymw's Avatar
I was searching in connectors in my manual but only I found an YEL/BLK wire (I was not sure correctness), my oversight.
2pac1
06-28-2019 10:25 PM
hondamyheart
03-14-2019 04:42 AM
Sk33t-EM1
01-17-2011 09:45 AM
xrdriver
Audio / Security / Video
10-17-2009 04:58 PM
Quick Reply: 2000 Civic DRL system - Two cables
