1999 Honda Civic EX flickering lights (strobing, pulsating)
Old 09-16-2008, 03:40 PM
danaofsac's Avatar
Default 1999 Honda Civic EX flickering lights (strobing, pulsating)
OK, the dealer says there is nothing wrong... But my dash, head and interior lights flicker. It is like a strobe light but not bright and seems to be happening all the time or at least a few minutes after driving. Also the SRS light started coming on and the dealer says there are no codes present for the SRS light to indicate a problem. I also had to replace the battery, which had another 4 years of life on it but was now bad. I have no idea what this is. Has anyone heard what might be causing this.
Old 09-16-2008, 03:49 PM
chickenwing's Avatar
Default Re: 1999 Honda Civic EX flickering lights (danaofsac)
did you check the output of the alternator?
Old 09-16-2008, 09:59 PM
jers99's Avatar
Default Re: 1999 Honda Civic EX flickering lights (chickenwing)
my dash kinda does the same. kinda like when I had subs but I haven't had them in years and have bought a new alternator and battery. bump for some info
Old 09-16-2008, 10:02 PM
SovXietday's Avatar
Default Re: 1999 Honda Civic EX flickering lights (jers99)
Sounds like the alternator is taking a ****, otherwise clean your grounds. Might as well do that latter reguardless, they should be cleaned as often as your oil changes honestly.
Old 09-16-2008, 10:16 PM
racerxh00's Avatar
Default Re: 1999 Honda Civic EX flickering lights (SovXietday)
yea, check your grounds, go to someone who sells batteries and have your charging system checked. wal mart automotive has midtronics battery testers and so does checkers/schucks/kragen
Old 09-17-2008, 12:32 AM
HT Black Ops
92 civic VX B18c's Avatar
Default Re: 1999 Honda Civic EX flickering lights (racerxh00)
I've been having the same issue for a long time now.. Although I replaced the alt about 2 years ago so I didn't even consider it in the process of trying to find what was causing this...
Old 09-17-2008, 09:01 AM
danaofsac's Avatar
Yes, Honda had it for a day and tested it and said it was fine. I also read somewhere that a bad distributor might cause this as well. I just don't want to shell out and replace all these things and still have the problem.
Old 09-17-2008, 09:39 AM
SovXietday's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danaofsac &raquo;</TD></TR><TR><TD CLASS="quote">Yes, Honda had it for a day and tested it and said it was fine. I also read somewhere that a bad distributor might cause this as well. I just don't want to shell out and replace all these things and still have the problem.</TD></TR></TABLE>
Like I said, clean and redo the grounds in your engine bay at the very least. It's free and it could very well fix many of your electrical problems.
Old 09-17-2008, 10:02 AM
obuhmyuh's Avatar
i think its your grounds. alternator would be a slow dimming of everything, untill the eventual ****-taking. sounds like something is loose/damaged/dirty.
Bethiecaute
Honda Civic (2006 - 2015)
06-01-2015 12:54 PM
homero
04-04-2012 10:39 AM
stevey40
12-10-2010 06:55 AM
joenoreason
03-13-2007 09:55 AM
stigedis
02-12-2007 04:07 PM
Quick Reply: 1999 Honda Civic EX flickering lights (strobing, pulsating)
