***Official FS/WTB/WTT Thread*** (Read the rules before posting)
Old 09-24-2008, 10:15 AM
Daisy... Daisy...
Dogginator's Avatar
Default ***Official FS/WTB/WTT Thread*** (Read the rules before posting)
A thread like this is a privilege, not a requirement for this forum. Follow all of the following rules if you decide to post in this thread. If you cannot follow the rules, do not post.
Here are the rules:
1) No trial users can post here. If you do, your post will be deleted.
2) This thread is for transmission and drivetrain related parts only.
3) A user may only have three posts in this thread at any given time. You are allowed one FS, one WTB, and one WTT post. If you violate this rule, all of you posts in this thread will be deleted and you will be docked.
4) Follow the posting format below.
5) You must include a link to the FS/WTB/WTT thread in the Marketplace. Do not post links to any other sites, such as Ebay, Craigslist, etc. If you do, your post will be deleted and you will be docked.
6) This is the only thread in the Transmission & Drivetrain Forum where FS/WTB/WTT posts are allowed. All other FS/WTB/WTT threads will be locked or deleted.
7) Do not post any commentary. This includes flaming and questions. This will be STRICTLY enforced.
8) Do not post ANY pictures in this thread.
9) Do not use the SIZE command in this thread.
10) If you have a question or comment, send an IM to the user or post in the linked Marketplace thread.
11) The mods reserve the right to delete any posts.
12) This thread will be purged with a rolling deletion periodically.
Posting Format:
Type: (choose FS, WTB, or WTT)
Description: (Describe the FS/WTB/WTT.)
Link: (You must provide a Marketplace link.)
Dogginator is offline
Daisy... Daisy...
Dogginator's Avatar
Default Re: ***Official WTB/WTB/WTT Thread*** (Dogginator)
Bense can change this thread as he wishes.
Old 10-06-2008, 02:57 PM
logg_frogg's Avatar
WTB: B16 hydro tranny or second gear gearset (2.105) for b-series
http://www.hondamarketplace.com/zerothread/2403718
Modified by logg_frogg at 12:38 PM 10/7/2008
logg_frogg is offline
Old 10-12-2008, 06:08 AM
CubanoRockr's Avatar
WTB final drive in 4.785 or 4.9 lmk what you have i can use either b16/ls or the gsr/type-r diff set
http://www.hondamarketplace.co...id=60
Modified by CubanoRockr at 12:12 AM 10/17/2008
CubanoRockr is offline
Old 10-19-2008, 09:46 PM
oldskool teggy's Avatar
Default Re: ***Official WTB/WTB/WTT Thread*** (CubanoRockr)
FS:
lots of OEM transmission parts, lsd, final drives, OEM gearsets, main and countershaft gear stacks.. all in good condition!
http://www.hondamarketplace.com/zerothread/2419707
Modified by oldskool teggy at 4:42 PM 10/29/2008
oldskool teggy is offline
Old 10-21-2008, 03:23 PM
sackdz's Avatar
Default FS: B series bearings for rebuild
FS:
Bearings for B series transmission rebuild. 6 total.
http://www.hondamarketplace.com/zerothread/2413889
sackdz is offline
Old 10-22-2008, 09:22 AM
MrXclusivE's Avatar
WTB: B16 tranny with LSD
http://www.hondamarketplace.co...id=68
Modified by MrXclusivE at 1:43 PM 10/22/2008
MrXclusivE is offline
Old 12-12-2008, 03:47 PM
paopao's Avatar
FS: OEM ITR LSD
Low mileage LSD taken from an ITR trans bought straight from Acura. Comes w/OEM bearings and ring gear.
$450 shipped, or $400 shipped w/out ring gear. Buy this instead of OBX!
http://www.hondamarketplace.com/show....php?t=2450677
paopao is offline
Old 12-23-2008, 08:37 AM
not so civic's Avatar
Location: gravity rides everything...everything will fall, se GA/ne FL
Default Re: ***Official WTB/WTB/WTT Thread*** (Read the rules before posting)
LSD for sale: cusco
http://hondamarketplace.com/showthread.php?t=2455580
not so civic is offline
Old 01-08-2009, 06:15 AM
Singlecam4dr's Avatar
wtb grind free si or zc transmission. has to be an 88 with a 20 spline output shaft thank you
http://www.hondamarketplace.com/show...7#post36938157
Singlecam4dr is offline
Old 01-22-2009, 11:30 AM
Derek128's Avatar
found one in local
thank you
Derek128 is offline
Old 01-22-2009, 09:11 PM
D Tranny Guru
Mista Bone's Avatar
No such transmission exsists, 88 had 21 splines. 89-91 have 20 splines
Mista Bone is offline
Old 01-26-2009, 07:39 PM
crxtra's Avatar
WTB
plz help me i need this part very bad an accident left my 91 crx si tranny unusable
i need the outer must case of the transmission the part with out the tranny guts in it my tranny fell off a work bench and broke the treads where u take the tranny apart at so unless i find a 91 crx si case half or an other tranny case that will fit it is a 5speed
plz help me if u can give me a price shipped to
404 east main la-farge,wisconsin 54639
crxtra is offline
Old 01-26-2009, 11:34 PM
D Tranny Guru
Mista Bone's Avatar
You need the passenger side case only correct?????
I'll check my scrap alum. pile, I scraped out a few trannys a while back due to bad ISB's, the outer case would still be useable.
NOTE: You WILL have to shim both the mainshaft and the diff.
Old 01-27-2009, 11:29 AM
crxtra's Avatar
yes the passenger side
thanks for the reply any help would be great
crxtra is offline
Old 01-27-2009, 04:44 PM
johnsc2235's Avatar
Looking for a ITR LSD....Looking to spend Less than $400 shipped depending on condition and miles.
johnsc2235 is offline
Old 01-31-2009, 07:56 AM
jdm_eg's Avatar
Default WTB D SERIES TRANNY 1996-00 ek or anything that fits
Need a tranny ASAP # is 717-875-3962 i would prefer something i could pick up within a couple hours of Lancaster, PA 17601. If you got anything get at me!
jdm_eg is offline
Old 02-02-2009, 09:29 PM
FIGARILA's Avatar
Default FS: used A1 LS 5th gear set, New bearings and seals for a 90 SI tranny.
http://hondamarketplace.com/showthre...dabe&t=2490536
FIGARILA is offline
Old 02-04-2009, 03:49 PM
crxtra's Avatar
bump
wtb
any one with a 90-91 civic/crx dx or si 5 speed tranny case pass side
plz hit me back
some one gotta have one cant find one any were
crxtra is offline
Old 02-11-2009, 06:31 AM
pgpbubble's Avatar
USDM B16A2 S4C Bell Housing, Great condition, legit. Vin intact. $100 OBO.
pgpbubble is offline
Old 02-14-2009, 09:56 PM
nytosc's Avatar
Location: New York in the summer, South Carolina in the winter
WTB: LS 5th gear parts needed to put into a B16 transmission (hydro of course)
nytosc is offline
Old 02-15-2009, 11:59 AM
MHBb16CRX's Avatar
WTT.
I have a 90 integra Tranny in very good shape. NO grinds. I want to trade this Tranny for
a good All motor tranny for my b18a. short geard. must have LSD, and must be cable, NO GRinds. LS 5th gear would be nice but not a must. also this tranny should be computable with my clutch.
MHBb16CRX is offline
Old 02-15-2009, 12:35 PM
Civic89stdB16's Avatar
found what was looking for. thanks
Civic89stdB16 is offline
Old 02-21-2009, 04:10 PM
pgpbubble's Avatar
WTB: 3rd & 4th Carbon Syncho for B16A S4C transmission; LSD for USDM b16 trans; and a 3.070 or 3.077 First gear.
Old 03-04-2009, 02:17 PM
ALLMOTA92EG's Avatar
WTB: b16 2nd, 3rd, 4th for a hydro trans
ALLMOTA92EG is offline
Quick Reply: ***Official FS/WTB/WTT Thread*** (Read the rules before posting)
