D.I.Y EDM / JDM EK (96-98) Clock install
Old 04-16-2012, 04:27 PM
thusee's Avatar
Default D.I.Y EDM / JDM EK (96-98) Clock install
There really isn't a D.I.Y for this so this is for the noobs that cant figure it out
Here's the clock: i got the Amber one since my cluster and everything is pretty much amber lighting. The other option is the White lighted clock. Make sure if your getting the clock from someone on Ebay or local seller that you get the harness with it as I have read that many people don't include the harness. The harness is a blue plug with 4 wires coming out.
Wire code for the clock:
Yellow: 12v
White/blue: Illumination and Memory
Red/Black: Dimmer
Black: Ground
Step 1: Remove the Climate Control / Audio Bezel whatever you want to call it.
There are DIY for this so search!
Kidding heres a good DIY although i took mine apart myself without any issues but this will help whoever doesn't know.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-replacement-climate-controls-bezel-96-98-civic-2884447/
Step 2: Wiring of the factory Clock harness
I simply wired it up to the factory radio harness as it had all the wiring that i needed to operate the clock.
NOTE: Don't wire it up to any aftermarket harness you may have plugged into the factory harness.
REASON: if you ever decide to change the deck or your deck gets stolen with the adapter you may need to re wire the clock again...so to be safe just wire it up to the factory harness.
Wiring: Match up these wires. Only one wire is different from the factory radio harness which is the yellow wire.
Heres the picture of all 4 wires T joined with the factory harness and Soldered.
I like to keep my wiring clean so i taped each wire up individually then taped it up with the wire loom. So it looks oem
Step 3: Install clock on Bezel
When you flip the bezel over you will notice beside where the radio sits it has 2 holes. I put in screws so you can see what im talking about...this is where the clock sits. The holes are not threaded so you will need to get screws that will thread into it.
Installed
And the final product after the bezel and everything installed
NOT RESPONSIBLE IF YOU MESS UP!
thusee is offline
Old 04-16-2012, 04:35 PM
canadaek's Avatar
Default Re: D.I.Y EDM / JDM EK (96-98) Clock install
could u make the pics smaller.
canadaek is offline
Old 04-16-2012, 04:53 PM
TriniSpeC's Avatar
That^. But this is a really slick looking piece. I really miss the digital dash clocks from back in days lol.
TriniSpeC is offline
Old 04-16-2012, 05:09 PM
thusee's Avatar
Will make pics shorter im used to jdmr where pics auto size didn't realize this forum doesn't. ill update it tomorrow.
thusee is offline
Old 04-16-2012, 05:31 PM
Yo Pintura Trenes's Avatar
For anyone who needs to make the pictures smaller on their screen:
Mac Command+"minus" key
Win Control+"minus" Key
Yo Pintura Trenes is offline
Old 04-16-2012, 06:03 PM
deving916's Avatar
It's so much better then that stock pocket.
I have the white clock
deving916 is offline
Old 04-16-2012, 07:23 PM
thusee's Avatar
Nice clock lol....i went with amber because it suits my dash and switches
thusee is offline
Old 04-16-2012, 07:32 PM
deving916's Avatar
word me too, I wanted to go with a 'white' theme. I always see the amber. I bought an amber and white, they both look good.
Old 04-17-2012, 12:33 AM
R.I.P. Mark
MRGRIM's Avatar
that looks great
like it was ment to be there
and ill bet your happy
MRGRIM is offline
Old 04-17-2012, 07:04 AM
deving916's Avatar
^^^ This guy is my hero lol
It's nice to have friends in other countries that can help you get cool stuff
Old 04-17-2012, 07:51 AM
thusee's Avatar
Download PDF here for those of you complaining about size
https://docs.google.com/open?id=0B4w...EdhZjhRaEdITmc
thusee is offline
Old 05-06-2012, 07:03 PM
ecko_3420's Avatar
What if the clock did not come with a pigtail harness??
ecko_3420 is offline
Old 05-14-2012, 11:09 AM
thusee's Avatar
you will need to find another harness that can work with it....
1) go to the junk yard and see which other harness will plug in and snip it out...
2) or order one from UK.......
3) or make your own
thusee is offline
Old 05-14-2012, 12:02 PM
My97CX's Avatar
Hmm I tried wiring it using
But first time it didn't work and now I have it wired to red/black factory harness to yellow clock and red/yellow factory harness to red/black clock wire and it works but it just won't turn off now and makes that annoying beep sound when I open the driver door. What could be the problem?
My97CX is offline
Old 05-14-2012, 02:43 PM
thusee's Avatar
could you send me a pic of the original harness you got with the clock? or post it here?
thusee is offline
Old 05-14-2012, 03:00 PM
ecko_3420's Avatar
Do you knw which harness fits??
Old 05-14-2012, 03:33 PM
thusee's Avatar
sorry dont know...
thusee is offline
Old 07-25-2016, 12:17 AM
charlietse's Avatar
hi, i just followed this guide but the only way for my clock to work is when my headlights are turned on. can anyone point me in the right direction to how to fix this?
charlietse is offline
Old 07-25-2016, 07:36 AM
Former User's Avatar
Create your own thread.
Former User is offline
My97CX
05-14-2012 12:10 PM
d16y7ej6dude
08-09-2008 02:13 PM
ilikejesus
Audio / Security / Video
06-15-2007 05:01 PM
S2k Hybrid
05-03-2007 11:15 PM
screech
03-02-2004 03:13 PM
Quick Reply: D.I.Y EDM / JDM EK (96-98) Clock install
