Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Tire pressure que...
Old 10-15-2006, 03:05 PM
NA4sho's Avatar
Default Tire pressure que...
on the door panel it says...cold tire pressure front 32psi and back 29 psi...so does that mean it should be measured at when its kinda cold out?
Old 10-15-2006, 03:30 PM
SteaveO2's Avatar
Default Re: Tire pressure que... (NA4sho)
No, it's means check them before u drive it not after. Your tires warm up from driving.
Old 10-15-2006, 07:03 PM
honda06si's Avatar
if youve still got summer air in your tires, you need to let all the air out and switch to winter air. or youl be in a world of hurt
Old 10-15-2006, 07:45 PM
NA4sho's Avatar
Default Re: Tire pressure que... (honda06si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda06si &raquo;</TD></TR><TR><TD CLASS="quote">if youve still got summer air in your tires, you need to let all the air out and switch to winter air. or youl be in a world of hurt</TD></TR></TABLE>
Umm...don't I just put more air on top of depressured air from the cold? it's just that air molecules are moving slower in colder temp...pv=nrt for ideal gas...there is no difference between summer air and winter air...maybe u meant something else...?
Old 10-16-2006, 03:26 AM
Michael Bolton's Avatar
LOL
Old 10-16-2006, 03:39 AM
n3twrkm4n's Avatar
Default Re: Tire pressure que... (Michael Bolton)
Tire pressure varies when warm +/- 4 to 6 PSI. So they say, the advice above is valid except the summer air one... hahaha
Check your tires when cold, like when you get up in the morning and before you go driving...
Old 10-17-2006, 02:48 PM
spoonlongblock's Avatar
or just go to NTB and ask them for a Tire Flush. They fill you tires with nitrogen instead of air... now that awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 10-17-2006, 04:29 PM
NA4sho's Avatar
Default Re: Tire pressure que... (spoonlongblock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonlongblock &raquo;</TD></TR><TR><TD CLASS="quote">or just go to NTB and ask them for a Tire Flush. They fill you tires with nitrogen instead of air... now that awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! </TD></TR></TABLE>
that sounds great cuz i know from chem class that nitrogen is not an ideal gas, hence not a big fluctuation in pressure due to temp change right?....what does NTB stand for again? and how much does it cost?
Old 10-17-2006, 06:00 PM
Beefkake's Avatar
NTB stands for National Tire and Battery.
syedshah
Honda Fit
09-24-2011 08:48 PM
doubleoazn03
10-17-2008 07:37 PM
96Civic_Coupe
03-21-2006 12:37 PM
speedracer33
11-05-2004 07:30 AM
608 Gangsta
10-18-2004 01:12 PM
Quick Reply: Tire pressure que...
