Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Honda MTF Flush Update !
Old 12-20-2007, 08:13 PM
WILD_WILL's Avatar
Default Honda MTF Flush Update !
I recently hit 31k miles and i was def due for a tranny fluid flush ive been sitting around for a couple of months trying to decide which fluid to go with. I purchased 2 quarts of updated Honda mtf and flushed the tranny today with a fellow Si owner and freind. I instantly felt the difference in 3rd gear it goes in smooth every time now i was getting bad notchyness and lock outs since like 12k miles. It feels smoother in every gear now i was getting slight notchyness in reverse,1st,1st to 2cd its all gone now and the car just feels that much smoother as a whole. If any 1 is having the same issues put some new Honda stuff in before going after market i like it alot
PS - I have an 06 so i doubt the updated fluid was in there when i bought it also the tranny was slighty overfilled when we flushed it i put 2 quarts but i let the excess drip out before putting the bolt back on less then 2 quarts is needed according the the Honda manual.
Old 12-21-2007, 12:51 PM
SIchodelic's Avatar
I put in Amsoil and I still get the 3rd gear notchiness...
Old 12-21-2007, 02:04 PM
exhaust_note's Avatar
I did mine at 5K with Honda MTF and I plan on doing it again at 15K.
Old 12-21-2007, 03:03 PM
Gilgamesh's Avatar
Default Re: Honda MTF Flush Update ! (WILD_WILL)
REPOST.
Just bustin ya ***** man. Honda's new MTF is niiice.
Old 12-21-2007, 07:24 PM
NO MERCY!
RICO_'s Avatar
Default Re: (SIchodelic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIchodelic &raquo;</TD></TR><TR><TD CLASS="quote">I put in Amsoil and I still get the 3rd gear notchiness...</TD></TR></TABLE>
Oh good. I was debating whether to use AMSOIL or the new Honda MTF. And you just helped make my decision.
Old 12-22-2007, 08:19 AM
clemsonhatch's Avatar
Default Re: (RICO_)
I did the new Honda MTF flush and shifting is much better. I haven't had any issues with 3rd anymore. It still is bothersome that we are having this issue in the first place. The whine in 4th is still there
Otherwise the car is great so far!
Old 12-22-2007, 10:55 AM
haby red fg2's Avatar
Default Re: (RICO_)
i put amsoil in mine with about 10k on it and have no problems but then again i didnt have any tranny issues prior
i have about 30k on my si now and it is still smooth
Old 12-22-2007, 11:01 AM
k_civic's Avatar
I change mine twice and still pop up in 3 gear with MTF...
Old 12-22-2007, 12:55 PM
Tickle-shits
Tokyosmash!'s Avatar
Default Re: (clemsonhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clemsonhatch &raquo;</TD></TR><TR><TD CLASS="quote">I did the new Honda MTF flush and shifting is much better. I haven't had any issues with 3rd anymore. It still is bothersome that we are having this issue in the first place. The whine in 4th is still there
Otherwise the car is great so far! </TD></TR></TABLE>
The whine is normal, never going to go away.
Old 12-22-2007, 05:35 PM
reaper702's Avatar
Default Re: (Tokyosmash!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tokyosmash! &raquo;</TD></TR><TR><TD CLASS="quote">
The whine is normal, never going to go away.</TD></TR></TABLE>
what whine?
amsoil put in my fg2 for the last 13k and won't put anything but amsoil from here on out. tried royal purple but it was just as wack as the original MTF.
Old 12-22-2007, 06:05 PM
Ichi'san says...... " Oil is not Whiskey, so dont waste your money. Just use the oil that is recommended by your dealer."
its all the same, just change it often.
Old 12-22-2007, 10:09 PM
reaper702's Avatar
Default Re: (exhaust_note)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exhaust_note &raquo;</TD></TR><TR><TD CLASS="quote">Ichi'san says...... " Oil is not Whiskey, so dont waste your money. Just use the oil that is recommended by your dealer."
its all the same, just change it often.</TD></TR></TABLE>
speaking in MTF terms, i beg to differ.
Old 12-22-2007, 10:38 PM
jdmitr's Avatar
Default Re: (RICO_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICO_ &raquo;</TD></TR><TR><TD CLASS="quote">
Oh good. I was debating whether to use AMSOIL or the new Honda MTF. And you just helped make my decision. </TD></TR></TABLE>
I put my money on Honda! They not only engineer transmissions, they make them...Plus they have a lot more money than amsoil! Do you want a product that is meant for 70 different kinds of transmissions big and small, or do you want a fluid that is engineered for you specific trans? Amsoil =
Old 12-22-2007, 11:56 PM
Crasian's Avatar
Default Re: (jdmitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmitr &raquo;</TD></TR><TR><TD CLASS="quote">
I put my money on Honda! They not only engineer transmissions, they make them...Plus they have a lot more money than amsoil! Do you want a product that is meant for 70 different kinds of transmissions big and small, or do you want a fluid that is engineered for you specific trans? Amsoil = </TD></TR></TABLE>
true true. hondas are very picky with there fluids
Old 12-23-2007, 03:32 AM
Nighthawk R18's Avatar
lookin to change my MTF as well real soon.
how much did 2 qts of mtf from honda run you?
i still cant decide between honda and amsoil
are there any differences considering i have a base model civic?
thanks
Old 12-23-2007, 07:47 AM
WILD_WILL's Avatar
Default Re: Honda MTF Flush Update ! (Nighthawk R18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk R18 &raquo;</TD></TR><TR><TD CLASS="quote">lookin to change my MTF as well real soon.
thanks </TD></TR></TABLE>
Like $15 for both just go with the Honda mtf 1st its cheap and i would rather stay OEM before going after market so far so good with the new fluid
Old 12-23-2007, 08:09 AM
my cost was something like $5 for 2 quarts.
this is a no brainer, cant go wrong w/ honda mtf.
Old 12-23-2007, 08:38 AM
Default Re: Honda MTF Flush Update ! (exhaust_note)
awesome.
is the tranny fluid the same for both the Si and base model? or is there a specific type/grade i should ask for at the parts depo.
Old 12-23-2007, 09:25 AM
just ask for MTF. its all the same.
Old 12-23-2007, 02:39 PM
dope. thanks
Old 12-24-2007, 06:05 AM
The newest formula has a green label. I convinced the dealership to give me the MTF. We shouldn't have to change the fluid because the tranny doesn't feel right from the factory. I still think it's weird that they put in the wrong oil at the factory but it's shifting good now so
krazycivic4u
06-03-2006 08:18 PM
RopethisS2K
05-03-2006 10:11 PM
integraboi1010
05-21-2004 09:50 AM
Nameless RB26
01-23-2003 08:24 PM
Money Hou$e
04-24-2002 04:46 PM
Quick Reply: Honda MTF Flush Update !
